It is well connected with PdaNet and everything works for now, but then what?
Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Have you selected install from the PDA.net app. Once the drivers installed disconnect the cube, power off, start the flash tool, select download and then connect the cube via USB.900Supersport
freaktab developer
I have a tablet with new original firmware Cube of 03 September and I would be keeping this Rom but i like with permissions Root. I have installed a update.zip that came out in this forum but not working for me, maybe because other more modern firmware. Someone tell me how to get Root in my case? I can install the fix to upgrade to 6gb space for apps in this Rom Cube or any other fix being Root, or not have to be root to install fix?
Thank you very much for your help
Originally posted by jherraizm View PostI have a tablet with new original firmware Cube of 03 September and I would be keeping this Rom but i like with permissions Root. I have installed a update.zip that came out in this forum but not working for me, maybe because other more modern firmware. Someone tell me how to get Root in my case? I can install the fix to upgrade to 6gb space for apps in this Rom Cube or any other fix being Root, or not have to be root to install fix?
Originally posted by EAJaart View PostI install the drivers using PDA yes but when I turn off my tablet PDA recognize her.Originally posted by EAJaart View PostPDA is not connected when my tablet is off.
Regards, Edy.
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by EAJaart View PostPDA is not connected when my tablet is off.900Supersport
freaktab developer
I had same problem and solved by this way :
- Tablet off
- Apply SP Flash Tool on PC
- Plug USB Tablet
- if nothing appears, try to switch on tablet
Then update is ok and you will never see this problem for future updates ...Cube U65GT Talk9X 32go
Brian's rom and Lepi's white TWRP
Originally posted by Spassknochen View PostThanks in advance, Edy
That is what I meant.
I have to work now and give it a try later
My New Bootlogo is shown as my avatar
I like it as it is for now and it was pretty easy to change it
Thanks in advance again for all the help
Sent from my U65GT via chrome
Originally posted by Spassknochen View PostWatch out @uncle Google for this:
iGO primo Israel 2.4 9.6.29.427562 [KitKat].apk
The Rest oft needed files should be easy to find if you have found the apk...
If you have no luck, I can give the links just at weekend.
Hope that helps...
Thanks for the suggestion, but my problem is not to get the apk. I've got everything I need, at least I think!
My problem is that after installation, I get the error message saying that my tablet resolution is not supported.
When did you install iGO in your Cube, did you set a particular sys.txt or did you use a particular data.zip or skin?
I've tried more than one apk but always the same issue. I've alsotried to write the following in the sys.txt but nothing:
screen_xy="1024_768:2048x1458/1536x1970:fullscreen"
I've also tried to add my resolution in datazip/ui_android/multimode.ini, but nothing!
I really don't know what else I can do!
Originally posted by hawky View PostI had same problem and solved by this way :
- Tablet off
- Plug USB Tablet
Flashed this rom asap after my tablet arrived todayThanks for your work!
Everything went smoothly, but I cant find the cwm recovery you mentioned in the description.
Edit: got itI should have cwm by now. The description in the rom package differs from the one in this thread, so I was a bit confused.
Originally posted by EAJaart View PostI finally managed to flash your ROM it seems !! But I'd like to know how to have a recovery mod please!
There are currently 2060 users online. 1 members and 2059 guests.
