Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
Originally posted by Poppeye View Postif you appreciate my efforts this is the link for any donation:
Originally posted by pluto69 View PostI know, the resolution is wrong, but it is what the error says!!!!
However, Thanks in advance for your pm!
in the meantime I'll try a fresh install of iGO.
Bye.
iGO primo Israel 2.4 9.6.29.427562 [KitKat].apk
The Rest oft needed files should be easy to find if you have found the apk...
If you have no luck, I can give the links just at weekend.
Hope that helps...Sent from my U65GT via chrome
Originally posted by Spassknochen View PostI have another question...
Is it possible to increase the Bluetooth audio?
With my Note 2 LTE there is a default_gain.conf in system/etc which I've modded...
But such a file doesn't exist in cube's library
Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
If you want more apps including dead trigger ll then search playstore for markethelper.
For charging I use the following http://www.amazon.co.uk/gp/product/B...?ie=UTF8&psc=1 available with UK and European plug.900Supersport
freaktab developer
Brian,
this is almost equal to our stock 2Amps, isn't it?
Did you find any decrease in charging time?if you appreciate my efforts this is the link for any donation:
Its always fully charged when I get up for work. I put it on charge last thing before going to sleep. Its basically a higher quality version of the original charger with a second port that I use for my phone.900Supersport
freaktab developer
NEED HELP
Hello, excuse me.
I have a tablet "CUBE U65GT" root.
But I can not install the latest firmware on Flashtool using your tutorial.
I do not have the recovery mod.
When I plug my tablet and I start off with Flashtool nothing happens. If you can help me please.
PS: I speak bad English, I'm french.
Originally posted by ac0935p View PostYes it is possible. If you get to MTK Engineer Mode (easiest via Mobile Uncle or secret dial code). There are options in there to change volumes. If you google "zopo zp900 volume settings" you will probably find forum entries that give some details about volume settings. I know its bizarre referencing another device, but I know they exist for the Zopo. I guess "MTK volume settings" might find stuff too.
I will look around this....
Maybe it will fix my Problem with the "quiet" Bluetooth speakers...
If I put the stereo plug in from Tablet to those speakers the sound is loud enough, but no handsfree telephone is possible then...
Thanks a lot again for helping hand...Sent from my U65GT via chrome
PS: I speak bad English, I'm french.900Supersport
freaktab developer
Originally posted by 900supersport View PostIts always fully charged when I get up for work. I put it on charge last thing before going to sleep. Its basically a higher quality version of the original charger with a second port that I use for my phone.
It's not for shure you will get a real 2Amp charger if just the label or the seller promise 2amps
I think, if the 2 Amps are real, the U65GT will charge faster with that than the stock charger can do that job...
I believe, if U R using REAL 2 or 2,5A you're safe for manufacturers quality differences.
The biggest problem is chinese solder... I never have seen such bad solder connections as the chinese ones...
That's my experience with such stuff over years...Sent from my U65GT via chrome
Originally posted by 900supersport View PostIf you want more apps including dead trigger ll then search playstore for markethelper.
You can't spoof another device (let say Samsung) like Finless has done in his v 1.5 ROM for Pipo M9Pro to make our tablet compatible with all app in Market and Riley with all his PiPo ROMs?
You are indebted to Cube for some reason?
Sorry for the approach, but we need to know these things and what we expect from you for further development.
Regards, Edy.
There are currently 1821 users online. 0 members and 1821 guests.
