Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
    I didn't install new drivers for this tab, the ones needed for my kingzone phone were enough.
    Do you run win 8? If yes, you have to turn off the driver signature. Look for a pdanet driver pack, this did the trick for me
    Sry I don't remember the whole process.
    After one day of heavy use I haven't encountered any bugs in this room But there's one thing I'm wondering. When the screen of the tab is off, and I press the power button to wake it up, it takes approximately 3 seconds till the screen is on.
    Is there some way to speed this up?
      AW: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
      Originally posted by bimbo10 View Post
      In other words, it does not fit into the screen.
      Is there any way to solve this problem?
      Xposed Framework => App Settings Module
        Ok thanks. Does xposed work if I use art as runtime? Wanted to give art a try on this tab
        I'm a bit scared of xposed as my previous experiences with it on my pipo weren't the best.
        Edit: lol, you answered bimbo10's question and not mine. I already wondered why I can't find something about this in the app settings module. I should read slower
          No it won't work with xposed
          Sent from my U65GT using Tapatalk
            I'm not convinced selecting art actually does anything on the cube.
            900Supersport
            freaktab developer
              Originally posted by pluto69 View Post
              Hi Spassknochen.
              Thanks for the suggestion, but my problem is not to get the apk. I've got everything I need, at least I think!
              My problem is that after installation, I get the error message saying that my tablet resolution is not supported.
              When did you install iGO in your Cube, did you set a particular sys.txt or did you use a particular data.zip or skin?
              I've tried more than one apk but always the same issue. I've alsotried to write the following in the sys.txt but nothing:
              screen_xy="1024_768:2048x1458/1536x1970:fullscreen"
              I've also tried to add my resolution in datazip/ui_android/multimode.ini, but nothing!
              I really don't know what else I can do!
              Try this "CUBEiGation" (sorry, that was the onlyway to upload my igo, you need 7zip to extract)
              It tooks over 4 hrs to upload (remember my simple, limited gsm-connection)
              Link deleted by myself cause copyrights
              If link doesn't work for you, please contact me!
              If link work, please reupp on another hoster.
              But please do it quick, because this is a free account and I think, the file is not online very long
              Thank you
              Sent from my U65GT via chrome
                Re: Cube Talk 9x U65GT ROM based on Cube's V 1.8 firmware of 3 September 2014
                I think that, for now, it only speeds up booting the OS, as on several other devices... Maybe less RAM usage too... But I have not tested it...
                  @Spassknochen
                  Thanx !!! Where do you place iGO folder ? On external SDCard ?
                  Cube U65GT Talk9X 32go
                  Brian's rom and Lepi's white TWRP
                    Full Navigation on U65GT
                    Deleted cause copyright rules.
                    Spassknochen
                      %%%% link deleted %%%%%%
                      Thank you
                      In the meantime I've solved my issue by simply changing one value in sys.txt.
                      I changed "tablet=0" into "tablet=1" and everything was OK!
                      However, thanks for your help.
                      Pluto69
                        @ Pluto69
                        Please delete the link in my quote because copyright issues.
                        I've gotten a pm that the links must be deleted.
                        Thank you
                          Originally posted by hawky View Post
                          @Spassknochen
                          Yes.
                            Pluto69
                            How is it possible ???
                            In the sys.txt tablet is preceded by the sign ; !!!
                              In my sys.txt,too.
                              Here is my working sys.txt:
                              ________________________________
                              [device]
                              devtype_fallback_to_model=1
                              [android]
                              ;fullscreen=1
                              ;tablet=0
                              has_physical_home_button=0
                              check_for_dead_links=1
                              check_folders_after_rebuild=0
                              getdeviceid_trycount=0
                              upside_down_bug=1
                              ;navigation_audio_stream=4
                              [rawdisplay]
                              force_renderer="RENDER_MOYA"
                              ;driver=engine
                              ;screen_xy="auto"
                              ;driver="gdi"
                              ;highres=1
                              [interface]
                              ;vga=1
                              show_glonass=1
                              extra_settings=1
                              save_checksum=0
                              minzoom2d=25
                              [debug]
                              imei="android.os.Build.SERIAL"
                              skip_eula=1
                              screenshotsavecameraini=0
                              experimental_features=1
                              show_networkservices=1
                              show_lane_info=1
                              show_junction_view=1
                              [sound]
                              csv_voice_enabled=1
                              ding_muted=1 ;Call off the team.
                              dev_channels=2
                              effect_volume="100" ;key - the "100" = one third sound, "200" = 3/4 volume, 300 = full volume
                              [warning.driveralert.settings]
                              max_display_count=3
                              show_timeout=10
                              show_vehicle_pictograms=1
                              preactivate_distance=300
                              warn_method=2
                              [dynamiccompressor]
                              TTS voice
                              compressor=1
                              gain=12
                              [navigation]
                              junction_view_blink_time=500
                              junction_view_blink_time_no_lane=500
                              junction_view_at_maneuver=1
                              junction_view_type="mixed"
                              junction_view_needs_signpost=0
                              ;junction_view_content_resolution_override="auto"
                              strict_ejv_resolution=0
                              [gps]
                              location_net=1
                              location_gps=1
                              ;this should be in android igo9 config:
                              background_navigation=1
                              location_log=0
                              location_log_filename="gpslog/LocationManager"
                              [folders]
                              linked_root_list="/storage/extSDCard/iGO /storage/sdcard2/iGO /sdcard2/iGO /sdcard/external_sd/iGO /ext_card/iGO /mnt/_ExternalSD/iGO /mnt/emmc/iGO /mnt/extern_sd/iGO /mnt/external_sd/iGO /mnt/exsdcard/iGO /mnt/ext_card/iGO /mnt/ext_sd/iGO /mnt/extsd/iGO /mnt/extSdCard/iGO /mnt/sdcard/_ExternalSD/iGO /mnt/sdcard/external_sd/iGO /mnt/sdcard/ExtStorages/iGO /mnt/sdcard/extStorages/SdCard/iGO /mnt/sdcard2/iGO /storage/sdcard1/iGO /storage/sdcard0/iGO /storage/iGO /sdcard/sd/iGO /mnt/sdcard-ext/iGO /mnt/sdcard/sd/iGO /mnt/sd/iGO /mnt/sdcard/iGO /mnt/iGO /sdcard/iGO /storage/sdcard1/iGO /mnt/sdcard1/iGO /mnt/ext/SdCard/iGO /storage/ext/SdCard/iGO /storage/emulated/0/iGO"
                              ;has_secondary_root=1
                              ;android_secondary_root_path="/mnt/sdcard/addons"
                              [feature]
                              back_exit=1
                              back_button=1
                              contact_poi=1
                              tmc_event_coloring=1
                              signpost_coloring=1
                              [other]
                              demo_enabled=0
                              [poi]
                              provider_filtering=1
                              featured_provider="netlocalsearch.naviextras.nokia "
                              [poi.netlocalsearch.naviextras]
                              services="nokia,google"
                              [tts]
                              automatic_direction_conversion=1
                              announce_exit_directions=1
                              always_say_road_names=3
                              announce_street_name=1
                              skip_exit_numbers=1
                              tts_buffer=131072
                              tts_logics=3
                              priority="HIGH"
                              ttspro_da_voice_enabled=1
                              tts_speedcam_sounddelay0=90
                              tts_speedcam_sounddelay1=140
                              tts_speedcam_sounddelay2=140
                              tts_speedcam_sounddelay3=140
                              tts_speedcam_sounddelay11=90
                              tts_speedcam_sounddelay17=140
                              [2d]
                              traffic_lights=1
                              [3d]
                              usepolyfarroads=0
                              [hnr]
                              ignored_missing_country_ids=*
                              [route]
                              hnr_ignored_missing_country_ids=*
                              [camera.roundabout]
                              enabled=0
                              centery=20
                              [map_update_checker]
                              enabled=0
                              [sound]
                              csv_voice_enabled=1
                              ding_muted=1
                              [network]
                              available=1
                              [http]
                              enabled=1
                              [tmc.src.http]
                              enabled=1
                              [tmc-http]
                              enabled=1
                              start=1
                              servers.size=3
                              servers[0].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-iphone/0/"
                              servers[1].url="http://zippy.naviextras.com/services/tmclite/data/nng-igo-tmc-russia/0/"
                              servers[2].url="http://tmchttp0.naviextras.com/nng-igo-tmc-primo/0/"
                              [naviextras]
                              boot_service_address="http://zippy.naviextras.com/services/index/rest/2/boot"
                              [services]
                              software_download_location="http://www.igomaps.co.il/Jquery_Report.html"
                              server_addr="https://android.naviextras.com/"
                              [warning]
                              speedcam_enabled=1
                              speedcam_warning=1
                              is_spoken=1
                              approach_beep_spoken_type=0
                              speedcam_max_lookahead=1500
                              speedcam_soundtype_1=2
                              speedlimit_ua_correction=0
                              speedlimit_warning_visual=1
                              speedlimit_warning_voice=1
                              ;speedlimit_warning=1
                              speak_tts_only=1
                              overspeed_sound=0
                              speedcam_maxdistance_from_road=10
                              speedwarn_alt_tolerance=110
                              speedwarn_tolerance=110
                              ;warn_distances=130:2000,140:1600,130:1400,120:120 0,110:1000,100:800,90:600,80:500,70:400,60:300,50: 200,40:100
                                by the way
                                Is there any way to use spflash in linux?
