Neomode Custom Rom Minix X5 mini Android 4.4
    0k try this
    Donate to Finless
      Will do bringing first my son to bed.
      Gesendet von meinem HUAWEI P7-L10
        Actually, I've got the full 8189es/etv source and compiled so this may be better
        test6
        I've pushed the changes to GIT so that you have too
        Donate to Finless
          Ok now i can insmod wifi.ko without error.
          PHP Code:
          352.637633
          ] =======================================================<4>[  352.644029] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====<4>[  352.650400] =======================================================<4>[  352.656766] =======================================================<4>[  352.663120] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====<4>[  352.669415] =======================================================<4>[  352.675712Realtek 8189ES SDIO WiFi driver (Powered by Rockchip,Ver 3.00init.<6>[  352.683142rk29sdk_wifi_power1<6>[  352.939356wifi turn on power<6>[  352.942198rk29sdk_wifi_set_carddetect:1<6>[  352.942220mmc1slot status change detected(0-1)<4>[  352.942311RTL871Xmodule init start<4>[  352.942330RTL871Xrtl8189es v4.3.0.2_10792.20140318<4>[  352.942355RTL871Xbuild timeSep 28 2014 19:45:34<4>[  352.942691RTL871Xmodule init ret=0<6>[  353.142268]<6>[  353.142281drivers/mmc/core/core.c...2019..  ===== mmc_rescan Begin....[mmc1]<6>[  353.186369]<6>[  353.186381mmc_attach_sdio..1112..  ===== Begin to identify card as SDIO-card. [mmc1]<6>[  353.200101rk29_sdmmc_change_clk_div..1684..  newDiv=0newCLK=25000Khz [sdio]<6>[  353.202934mmc1: new high speed SDIO card at address 0001<4>[  353.213398bFWReady == _FALSE call reset 8051...<4>[  353.239122RTL871Xrtw_ndev_init(wlan0)<4>[  353.245103RTL871Xrtw_ndev_init(p2p0)<6>[  353.252775sdmmc_rescan_try_freq..1867..  ===== Initialize SDIO successfully. [mmc1]<4>[  365.927098wlanUnknown symbol rkwifi_set_firmware (err 0)<4>[  368.782549wlanUnknown symbol rkwifi_set_firmware (err 0)<4>[  381.776169wlanUnknown symbol rkwifi_set_firmware (err 0
          PHP Code:
          root@X5 Mini:/system/lib/modules # iwconfigiwconfiglo        no wireless extensions.
          eth0      no wireless extensions.
          sit0      no wireless extensions.
          ip6tnl0   no wireless extensions.
          iw_get_stats return success.wlan0     unassociated  Nickname:"<WIFI@REALTEK>"          Mode:Managed  Frequency=2.412 GHz  Access PointNot-Associated          Sensitivity:0/0          Retry:off   RTS thr:off   Fragment thr:off          Encryption key:off          Power Management:off          Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
          iw_get_stats
          return success.p2p0      unassociated  Nickname:"<WIFI@REALTEK>"          Mode:Managed  Frequency=2.412 GHz  Access PointNot-Associated          Sensitivity:0/0          Retry:off   RTS thr:off   Fragment thr:off          Encryption key:off          Power Management:off          Link Quality=0/100  Signal level=0 dBm  Noise level=0 dBm          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
          root
          iw_get_stats
          root
          iw_get_stats
          255|root@X5 Mini:/system/lib/modules # lsmodlsmod
          wlan 853 0 - Live 0x00000000
          rk29_ipp 9957 0 - Live 0x00000000 (C)
          mali 152212 20 - Live 0x00000000
          ump 27958 11 mali, Live 0x00000000
          rk30xxnand_ko 162075 0 - Live 0x00000000
          We are very very close :-)
          No :-( The Card is no SIDO
          <6>[ 1013.712179] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc1]
          <6>[ 1013.756134]
          <6>[ 1013.756139] mmc_attach_sdio..1112.. ===== Begin to identify card as SDIO-card. [mmc1]
          <3>[ 1015.752178] mmc_sdio_init_card..625.. ====*Identify the card as SDIO , but OCR error, so fail to initialize. [mmc1]
          <3>[ 1015.752244] mmc1: error -110 whilst initialising SDIO card
          <4>[ 1015.752306]
          <4>[ 1015.752310] =====
          <4>[ 1015.752314] sdmmc_rescan_try_freq..1875.. ===== Initialize SDIO-card unsuccessfully!!! [mmc1]
            This is test6? What is not working now? I'm not clear what to do next.
            Donate to Finless
              Yes it is Kernel 6. I will reboot and then do a DMESG to make it Clear.
              Ray
                Here is the DMESG after Boot:
                dmesgww.txt
                Here is DMESG after Loading wlan.ko:
                dmesgwifi.txt
                Ray
                  <4>[ 228.746989] ================================================== =====
                  <4>[ 228.753389] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
                  <4>[ 228.759756] ================================================== =====
                  <4>[ 228.766119] ================================================== =====
                  <4>[ 228.772457] ==== Launching Wi-Fi driver! (Powered by Rockchip) ====
                  <4>[ 228.778789] ================================================== =====
                  <4>[ 228.785107] Realtek 8189ES SDIO WiFi driver (Powered by Rockchip,Ver 3.00) init.
                  <6>[ 228.792540] rk29sdk_wifi_power: 1
                  <6>[ 229.046098] wifi turn on power
                  <6>[ 229.049169] rk29sdk_wifi_set_carddetect:1
                  <6>[ 229.053195] mmc1: slot status change detected(0-1)
                  <4>[ 229.058072] RTL871X: module init start
                  <4>[ 229.061836] RTL871X: rtl8189es v4.3.0.2_10792.20140318
                  <4>[ 229.066991] RTL871X: build time: Sep 28 2014 19:45:34
                  <4>[ 229.072353] RTL871X: module init ret=0
                  <6>[ 229.252097]
                  <6>[ 229.252110] drivers/mmc/core/core.c...2019.. ===== mmc_rescan Begin....[mmc1]
                  <6>[ 229.296147]
                  <6>[ 229.296161] mmc_attach_sdio..1112.. ===== Begin to identify card as SDIO-card. [mmc1]
                  <6>[ 229.310071] rk29_sdmmc_change_clk_div..1684.. newDiv=0, newCLK=25000Khz [sdio]
                  <6>[ 229.313092] mmc1: new high speed SDIO card at address 0001
                  <4>[ 229.328455] bFWReady == _FALSE call reset 8051...
                  <4>[ 229.354451] RTL871X: rtw_ndev_init(wlan0)
                  <4>[ 229.358429] RTL871X: rtw_ndev_init(p2p0)
                  <6>[ 229.365639] sdmmc_rescan_try_freq..1867.. ===== Initialize SDIO successfully. [mmc1]
                  Seems that Wifi Initialize :-)
                  Ray
                    Test 7 & 8
                    Donate to Finless
                      Will test tomorrow. Getting some rest now. Thank you!
                        got to boot with test 6. damn you and Ray fast I found the cables lol....
                        wifi not working play store still says no connection.
                        that's with test6
                          My Playstore works over Ethernet
                            Not on mine I have another box I flash that one now too. mine doesn't connect just spinning circle.Both boxes don't connect to playstore just spinning circle n no connection message.retry.
                            I can open browser and gmail working too. downloads so network work?
                              D33 did you post 7 and 8 to test seen it then gone?
                                Post #39 - still there
                                Donate to Finless
