Neomode Custom Rom Minix X5 mini Android 4.4
I know how to unpackage the rom and change kernel with rk tool but this little beyond me. Is this new kernel ? Or from d33 previous posts in here. I still have 2 boxes here to play with this to see if wifi working. 😆Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
I'll try the rom but I'll need a run down on few things (slower them some on this) The image flasflash able by standard flash tool? If not give me walk through (been bricked before ok alot ok master of the brick wont be my last brick either lmao.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Use the rk tool to un pack neomode rom download the kernel from the link. Re pack the new kernew in the flash tool using the parts from the unpack. Switch kernel to one downloaded.
I understand neo instructions re terminal but bit lost on the adding the other zip.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostUse the rk tool to un pack neomode rom download the kernel from the link. Re pack the new kernew in the flash tool using the parts from the unpack. Switch kernel to one downloaded.
OK Dose somone have link for downloading neomode rom,TNX.
Originally posted by neomode View Postmake follow install terminal emulator and type the follow
su
cd system/lib/modules
insmod 8189es.ko
rmmod wlan.ko
insmod wlan.ko
then should work
root@rk3066:/system/lib/modules # cd /system/lib/modules
root@rk3066:/system/lib/modules # insmod 8189es.ko
root@rk3066:/system/lib/modules # rmmod wlan.ko
root@rk3066:/system/lib/modules # insmod wlan.ko
insmod: init_module 'wlan.ko' failed (No such file or directory)
There are currently 1968 users online. 1 members and 1967 guests.
