arnova 10b G3 4Gig A Snakekiller rom VERSION 3
    here's already another version;
    this rom is more cleaner now .
    i removed all the stock apps like
    -browser
    -google quick search
    -music player
    -gmail
    -sound recorder
    -voice search
    -talk
    you can install these apps with a special aroma installer zip for cwm recovery.
    just place the zip on sd and take ''install zip''
    tick the apps you want and click next.
    after installing just reboot and the app or apps are installed.
    i changed gallery with quickpic.
    now proper videoplayback .
    i added adaway too and speaker boost
    but be carefull with speakerboost , don't blow your speaker ok .
    now by default after flashing is
    -wifi is on
    -installing non market apps is on in settings.
    -auto screen brightness is activated.
    so people who flashed my previous rom.
    it is worth to flash it again with this version.
    the time has begon for a whole completely custom rom in the future.
    ps .
    some apps like archidroid etc. installing by default on sd and not on the tablet.
    when you restart your tablet these apps are not installed anymore.
    its a android 4.0.4 bug.
    how fix it , after installing these apps just move it to the tablet before you reboot the tablet
    don't forget after flashing , reboot the tablet after the startup wizard, for further use, because external sd isn't mounted after flashing.
    here's a preview off the bootscreen.
    preview of quickpic
    when you double tick on your screen you have a window full off settings
    just did a test with antutu benchmark
    here's a picture how aroma installer looks a like
    here's the link for the rom
    ROM -> Arnova 10b G3 - SnakeKiller 3.0 - ICS 4.0.4 EXT4, CWM, initd (191 megs)
    here's the link for the stock apps
    ROM -> Arnova 10b G3 - SnakeKiller 3.0 - ICS 4.0.4 stock aroma zip
    if you love my work please buy a coffee
    <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
    </form>
    -browser
    -music player
    -gmail
    -sound recorder
    -voice search
    -talk
    i changed default font with ubuntu fonts
    -wifi is on
    This looks really nice - but what do you mean by 'whole completely custom rom'....? What have you got planned.....?
      Re: snakekiller rom VERSION 3
      i mean more like cyanogen mod 9 or something
      Verstuurd van mijn ARN10bG3-Freaktab met Tapatalk
      </form>
        I've been running this rom since this morning and everything is running as smooth as the last ROM.
        The main difference was that it took a lot less time to put everything back, because many defaults don't have to be set.
        The new font package doesn't seem as sharp as the ICS font, but it's okay.
        I like the CMW zip feature you added. You might consider adding more Google apps, like the ones that come with Pettrus's App Injector app that came with Bob's earlier G2 ROM's. Maps, Earth, etc...
        Thanks for Speaker boost.
        Randy
        Randy
          is it correct my internal memory is showing 4gb and not 8gb
            because you use a rom for the 4 gig version and not for the 8 gig
            </form>
              Is there a version of u're rom for the 8gb as it's an excellent rom
                i ask bob for the 8 gig parameters ok .
                because thats the only difference wright?
                so i think with rktools just change the parameter file.
                i let you now ok.
                im happy you like the rom
                </form>
                  i let you now ok.
                  Cheers
                    no problem for making a zip like petrus app injector.
                    but google maps etc... are these apps installed as system apps or not
                    i just wanna know.
                    </form>
                      Yes, somehow the app Injector makes those system apps, and other stock apps that originally came with the stock ROM are not system apps. It was a way to debloat without excluding certain apps that some people wanted to keep.
                      As I recall, there were quite a number of apps included in the zip file. Try downloading the 10G2 ROM and take a look. I'm not sure, but I think it wasn't included in his later 2+ versions.
                      Randy
                      Randy
                        Try 1.5, it's in there.
                        Those apks will need updating.
                        Randy
                        Randy
                          I've been looking at CM9 and I don't see much offered that we don't already have. Aside from scoring a JB kernel, what's left to conquer on the G3?
                          Randy
                          Randy
                            On the App Injector issue I'm sure there's an option/flag in the zip file to force the application to install as a system or normal app. I'll have a search see if I can find the thread.
                            Found it : http://www.freaktab.com/showthread.p...t=app+injector
                            application name 1 installed as a system app,
                            file 1.apk, file 1a.apk, file 1.odex,/system/app
                            application name 2 installed as a user app,
                            file_2.apk, file_2.apk, file_2.odex,/data/app
                            "application name 3 installed as a system app, with comma in its name",
                            file 3.apk, file_3a.apk, file_3.odex,/system/app
                            "application name 4 installed as a user app, with comma in its name",
                            file_4.apk, file 4a.apk, file_4.odex,"/data/app"
                            Says also that some apps installed as system could cause boot issues....
                            Andy
                            Last edited by MrWeelson; 09 September 2012, 16:08. Reason: Added link to app injector thread
                              i maked one for user apps
                              because some google apps updating too much
                              what i included is
                              aupeo
                              blogger
                              current
                              deezer
                              drive
                              finances
                              flight frenzy
                              freecell
                              google+
                              intersection
                              latitude
                              listen
                              locale
                              maps
                              offers
                              orkut
                              playbooks
                              playmovies
                              reader
                              translate
                              let you know iff it works see you back in 15 min
                              </form>
