MK903V ROM OPTIONS
    百度网盘为您提供文件的网络备份、同步和分享服务。空间大、速度快、安全稳固,支持教育网加速,支持手机端。注册使用百度网盘即可享受免费存储空间
    Seams like a new update is out ,did anyone try it??
      I flashed it. Rooted and changed LCD Density to 240 with the Launcher3 app and it looks good. Netflix still doesn't work. Airpin Pro is preinstalled. Fwiw.
      Currently Inactive on Freaktab.com
      I use: MK903V | MELE F10 Deluxe | Roku 3600R
      RIP: MK808b | MK809III | PIPO M9 Pro
        Nice did u loose all after flash?? Google play works good??is posible to be make it an sd flash zip??
          I don't know how to do that. I have all my apps saved on an sdcard. Setting up SPMC now.
            SPMC??pls do a thorough test pls ,kodi??google play?etc i will instal it too soon
              Holy cow, the CPU goes all the way down to .126 Ghz, that should help with overheating. And I figured out that if you turn it off and power off the tv, it will turn back on when you power up the tv again. I'll test with Mele remote and soundabout to see if this is a good idea.
              SPMC Helix didn't work for my mk809iii, so I use 13.4. I'm new at this app, so I'm not a good tester, I just installed it, add the tvaddons fusion installer and use their auto configuration tool, and zero cache xml with some other add ons I like, but I revert the background and splash screen to the original...
                BTW: zero cache isn't a good idea because you stress your nand because of all the continues read/writes...
                RK3288 Devices
                - Overview BOX (LINK !)
                  hmmm the turning back the power with the TV I have it now with out this update ??
                    zero cache xml
                    If you want to use zero cache you should thinking about maping it to external SD
                    or optimize your advancedsettings.xml to use more RAM
                    RK3288 Devices
                      Maybe, I didn't know how to do it until now, so I never got a chance to try it on the old firmware. To be sure, I have it plugged into the wall, not the tv, so it's not because of that.
                      Any how, the firmware works, if you would like to try it out, it's your call, I just got tired of mine rebooting randomly so I took a chance.
                      Originally posted by no_spam_for_me View Post
                      I'll try to do the RAM option if zero cache is bad news for my eMMC.
                        weird I have mine plugged in to the wall because I have an old TV with no USB and up to now I didn't have any reboots ,hmm I will try it to see how it is,what about heat up?mine after 4 hours of use of video or game gets so hot
                          I think it was because of SPMC, but I don't know. It seems to happen when I use that app. So whatever updates they have, I have the latest. It's nothing special except that the CPU will run at near dead 126 mhz so that may have a minimal impact on heat if you run at conservative governor.
                            Hi guys. MK903V 16 Gb - stopped working all usb ports. The device boots and runs, but to manage them is impossible. No keyboard and mouse do not work. The device is not detected on your computer - flash is not possible. What can you do?
                              My custom Rom - TWRP backup
                              16 Gb version
                              8 Gb version
                                16 Gb version
                                8 Gb version
                                I just google translated that post and read through the whole thing.
                                Any idea who is behind the Handy Smart TV apps? Seems they are specific to Rockchip devices.
                                Edit: found the post here with more information. Installed to my MK809III and will test at home.
                                2nd edit: I think I may be able to fix my M9Pro thanks for the website, I will try this: http://4minipc.ru/programmy/232-prog...disk-tool.html
