MK903V ROM OPTIONS
Originally posted by mitchell4you View PostFinally it has arrived
- Manual
- Hdmi cable (female to male)
- Usb to micro-usb (otg) cable
- Micro-usb to IR cable
- Dc adaptor (5v 2.5A)
- Antenna
- Remote IR
The device it self.. feels solid alu
Lets see.. Im impressed
-boot-up in about 5sec
-installing appz realy fast
-screen scale.. i could exactly state the borders of my tv (16:10)
-no issue connecting to routers on ch11/13
-shutdown button is standby.. hold button and real shutdown option comes
--while in shutdown.. ir-reader is still active, you can boot the system using remote
---if you place ezroot.zip on internal sd, after boot..it will ask..found update, do you wish to install?
-display options: reset_bcsh,hue,satcon,contrast,brighness,movie mode,hdmi mode,output interface,screenscale
-first run Spmc 13.3.4.. amazing fast
Notes: My unit came preset
Hdmi set to 1080/60 (not to 'auto' detect)
Language : UK
After getting root: cputemp and android-tuner.. still report temp 2c
Cpu runs between: 312 and 1.8ghz //gov interactive // rockchip rk3288 flattened device tree
No pre-rooted Fw
It comes with xbmc 14 aplpha4 pre-installed // ram free: 1022mb
It only comes with standaard kitkat gui (that feels quite fast)
Rtlxl= ads work, vids jump ahead
Npo= ads work, live stream work, vids buffer problems
720/1080 trailers using spmc (5.1 only after tweaking)
Gaming: dont buy this unit for gaming.. The unit became realy realy hot, after playing riptide2 (smooth)
-it doesn't trottle down.. It seems
Antutu video tester 2.2 score: 320 (all 27 vids green)
Tronsmart mars g01 works
Vpn, sadly.. I forgot the password (after forced renew password)
Iplayer:
Demand5:
good info, thaks
How to install a new ROM
Hey I have looked all over and I see that there are a couple of ROMs for this device mk903v. The Stock ROM and a custom ROM. I noticed many people talk about how they tried the different ROMs. But other then on how to root this unit. No one mentions on how they are installing a new ROM. Can someone point me in the right direction. Is there a ROM install tool for this device. If so does someone have a link.
Or is the process to rename the img file to update.img and place it on the sdcard?
Thanks,
flashing the MK903V
Originally posted by Ted Hazlewood View PostHey I have looked all over and I see that there are a couple of ROMs for this device mk903v. The Stock ROM and a custom ROM. I noticed many people talk about how they tried the different ROMs. But other then on how to root this unit. No one mentions on how they are installing a new ROM. Can someone point me in the right direction. Is there a ROM install tool for this device. If so does someone have a link.
Thanks,
the two roms I tried are:
and
I already had rockchip batch tool v1.5 but here is the one for v1.7
Originally posted by Ted Hazlewood View PostI found the rockchip batch tool v1.5 and v1.7 Tried both tools. I got the drivers installed and both tools see the connected device in slot 1 (green) when I select the img file either of the two I have downloaded and then select upgrade it fails during the test device stage after a few seconds of flashing green. it goes red. Am I doing something wrong? Is there a recovery rom for this like TWRP?
I assume you are still working on it and didn't just update here and stop. How did it go?Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by budgetgeek View PostThis usually happens when there is a problem with the flash. After trying the flash, have you been able to boot it up with the default ROM? I haven't tried the Custom ROM on it, but the stock device works pretty well, if you know how to set it up (ez root, supersu, busybox, uninstall apps, etc).
That worked fine.
Now since I verified that it is rooted, I will try the process again using the batch tool kit v1.7.
Do you have a recommended ROM for this device?
Is there a ROM that will work with the recovery. A ROM in .zip format instead of .img?
Thanks in Advance
The stock ROM it came with keeps rebooting when I try to watch any video using any app.
I contacted Geekbuying who I purchased this from and they gave me the new ROM I posted earlier from Geekbuying. They wanted me to try that.
So thats the one I was going to install unless, unless someone has a better one.
Thanks for helping
So After I rooted the device. Using the RKBatchTool v1.7 and either of the two ROM's I provided earlier still fails on testing the device "Test Device Fail"
Does anyone know of a .zip ROM to be used with the recovery Manager, or how to convert a .img ROM to a .zip ROM to be used with the recovery Manager. I don't think it's as simple as zipping the .img into a zip, but if it is I'll try it.
Originally posted by Ted Hazlewood View PostThe stock ROM it came with keeps rebooting when I try to watch any video using any app.
Thanks for helping
The test device fail may be hardware related. Have you tried using the other micro usb port to make sure that isn't the problem?
I did notice that with SPMC 13.4 and possibly with Kodi or XBMC, whenever I use the stock remote and click too quickly using the d-pad in the middle, it crashes every time. I use my Mele remote the same way and it doesn't happen. *Update, it was USB power related, not firmware.*Last edited by budgetgeek; 26 June 2015, 16:49.Currently Inactive on Freaktab.com
Originally posted by budgetgeek View PostThis is the latest from Bosuntop. http://pan.baidu.com/wap/share/home?...629114&third=0
I did notice that with SPMC 13.4 and possibly with Kodi or XBMC, whenever I use the stock remote and click too quickly using the d-pad in the middle, it crashes every time. I use my Mele remote the same way and it doesn't happen. I might switch to a F10 Deluxe if it can hibernate the same way the stock remote does.
Originally posted by Ted Hazlewood View Post... "Test Device Fail"
and maybe als try to use AndroidTools like at post #1 shown..RK3288 Devices
- Overview BOX (LINK !)
Originally posted by mitchell4you View Postmmm.. i was looking for something else.. then i noticed a post about a new possible fw.. here
http://chinagadgetsreviews.blogspot....kat-442_0.html
I updated to the latest firmware listed above. Netflix works. I did not update it to the latest version to see if that persists, but once I extract the apk for this one, I will check on it. Just wanted to update the thread.
Update: still works after update. Randomly rebooting now, though. I think it may be a root issue. I will unroot it and see. First, need to uninstall some junk. Besides reboot by petrus, and SetCPU, I can't think of too many reasons to keep it rooted after debloating. I hope that isn't the cause of the reboots.
Update 2; May be that it was running hot. Power is off to cool down.
Final update; I tested it and can say most probably it was rebooting because it was overheating. SetCPU down to 1.4 ghz and cooled off and no problems. Still had to use updated Launcher3 and 240 lcd.density. It is a real updated firmware, not an offshoot. Maybe the next one will be 5.0.Last edited by budgetgeek; 02 June 2015, 21:06.Currently Inactive on Freaktab.com
There are currently 3097 users online. 2 members and 3095 guests.
