polaroid ptab8000 8" ics tablet. got su, but cant get market on it
Originally posted by lgmayka View PostYou should always be able to restore the stock firmware using these instructions on Polaroid's web site.
Originally posted by rvmclaughlin View PostI was going to try that tonight when the kids go to bed. I have read that when you go to restore stock, it will not recognize the tab because the specks are now different.?? Wondering if I need to somehow have at least the model number read ptab8000 instead of the PMID701. Correct me if I'm wrong, its the build.prop file that made this change. I would like to know what the original build.prop file looked like for the PTAB8000. After reading everything, I am understanding a little more. Although, I do not know what everyline of code does. I can get into safe mode on the tablet. What are your thoughts? Restore the ptab8000 firmware back on or select the pmid701? This is suppose to be my sons xmas present! lol, we shall see how far I get tonight. I have to do the rebate on this thing soon or return it.
You replaced the build.prop on the system partition, the OTA s/w shouldn't look at that since it's running off the recovery image.
Also, FWIW, you do NOT need to replace the build.prop. In fact it's a really Bad Idea.
Originally posted by rvmclaughlin View Postyes, I realized that after reading various post. That's why I was wondering what the original looked liked to compare. I just followed LiquidLimez Market fix. When you run the runme.bat it pushes his file to system.
Originally posted by dolorespark View PostOnce you're back in business, DON'T use any of the methods you've tried previously. Instead, use mbellot's instructions here: http://www.freaktab.com/showthread.p...ll=1#post39483 They're the best!
adb shell mv /system/bin/su /system/bin/su.old
adb shell ln -s /system/xbin/su /system/bin/su
and mbellots has
17. root@android:/ # rm /system/xbin/su
rm failed for /system/xbin/su, No such file or directory
18. 255|root@android:/ # ln -s /system/bin/su /system/xbin/su
Are they trying to achive the same?
I was able to restore the tablet. I am going to try again. I am going to take out the build.prop.
Will keep you posted.
Originally posted by rvmclaughlin View Postthey are almost the same with the exception that LiquidLImez has the runme.bat that copys all the files and it also push build.prop. There are 2 other lines in question that I ran at some point:
I modified LiquidLimez batch file (for my own purposes). If this helps anyone you are free to use it, but I am not responsible for any problems you might have as a result.
Code:@echo off echo ------------------------------------------------------------------------- echo _ echo www.freaktab.com created by LiquidLimez echo _ echo ------------------------------------------------------------------------- echo _ echo Modified for use with the PTAB8000 echo _ echo Make sure you have read the readmebefore going any further... pause set system_x=/system/framework call gapp s1 com.google.android.maps.jar call gapp s1 com.google.android.media.effects.jar call gapp s1 com.google.widevine.software.drm.jar set system_x= set system_x=/system/lib call gapp s2 libfrsdk.so call gapp s2 libspeexwrapper.so call gapp s2 libvoicesearch.so set system_x= set system_x=/system/etc/permissions call gapp s3 android.hardware.touchscreen.multitouch.xml call gapp s3 com.android.location.provider.xml call gapp s3 com.google.android.maps.xml call gapp s3 com.google.android.media.effects.xml call gapp s3 com.google.android.nfc_extras.xml call gapp s3 com.google.widevine.software.drm.xml call gapp s3 handheld_core_hardware.xml call gapp s3 tablet_core_hardware.xml set system_x= set system_x=/system/app rem call gapp s4 Gmail.apk call gapp s4 GoogleBackupTransport.apk call gapp s4 GoogleCalendarSyncAdapter.apk call gapp s4 GoogleContactsSyncAdapter.apk call gapp s4 GoogleFeedback.apk call gapp s4 GoogleLoginService.apk rem call gapp s4 GoogleMap.apk rem call gapp s4 GoogleQuickSearchBox.apk call gapp s4 GoogleServicesFramework.apk call gapp s4 NetworkLocation.apk rem call gapp s4 PackageInstaller.apk rem call gapp s4 Talk.apk call gapp s4 Phonesky.apk call gapp s4 VoiceSearch.apk rem call gapp s4 YouTube.apk set system_x= echo Do you want to remove Phone, SMS, Bluetooth services? set /p choice=Choose y or n: if %choice%==y goto appy if %choice%==n goto appn :appy cls echo Disabling Bluetooth.apk adb shell mv /system/app/Bluetooth.apk /system/app/Bluetooth.apk.old echo Disabling Mms.apk adb shell mv /system/app/Mms.apk /system/app/Mms.apk.old echo Disabling Provision.apk adb shell mv /system/app/Provision.apk /system/app/Provision.apk.old echo Disabling TelephonyProvider.apk adb shell mv /system/app/TelephonyProvider.apk /system/app/TelephonyProvider.apk.old echo Disabling VpnServices.apk adb shell mv /system/app/VpnServices.apk /system/app/VpnServices.apk.old echo Disabling NetworkMonitor.apk adb shell mv /system/app/NetworkMonitor.apk /system/app/NetworkMonitor.apk.old echo Disabling Network3gMonitor.apk adb shell mv /system/app/Network3gMonitor.apk /system/app/Network3gMonitor.apk.old echo Disabling shortcut3g.apk adb shell mv /system/app/shortcut3g.apk /system/app/shortcut3g.apk.old echo Disabling Phone.apk - (Requires Immediate Hard Power Off and Reboot) adb shell mv /system/app/Phone.apk /system/app/Phone.apk.old goto appn :appn goto complete :complete adb shell rm /data/local.prop echo _ echo Installation completed! Hope it Works!! It Will! echo Press any key to reboot PTAB8000, then unplug the USB cable. echo _ pause adb reboot
I remarked out a couple files in step four (Gmail, Talk, etc) because I didn't want/need them, and in the case of PackageInstaller it actually creates a nuisance problem.
Also, FWIW, I replaced the files in LL mod with ones from gapps-ics-20120429-signed.zip instead.
Originally posted by dolorespark View Postmbellot lays it out as well as you'll ever find (probably because he actually understands what he's doing). Read this: http://www.freaktab.com/showthread.p...ll=1#post39483AndroidPizza
Originally posted by AndroidPizza View Postmost of my trouble is installing adb. I don't know where to get drivers for the PTAB or how to install them. Any ideas?
The first step is to get ahold of the package - several have been mentioned in threads here on Freaktab. Any one should do and there are a gazillion of them out there. (Note: most include two "coinstaller" dlls but some older packages don't - given a choice, choose a package that includes them).
Next, see if the one you get succeeds in installing the driver. If not, please do this:
* open Device Manager then connect your tab to your PC
* a new entry should appear - probably under Other Devices and probably with a yellow mark
* doubleclick on it to open its Properties, then select the last tab at the top
* the item that's hilited should be 'Hardware ID' and look something like this: USB\VID_18d1&PID_0003&M_01
* copy whatever you see into a new posting and we'll take it from there
Note: I'm at work and our PCs are locked down, so I'm doing this from memory - adjust instructions accordingly
Originally posted by AndroidPizza View PostThat somewhat helps, but most of my trouble is installing adb. I don't know where to get drivers for the PTAB or how to install them. Any ideas?
Once the drivers are installed you should be able to use adb (also included in the LL archive).
Make sure you enable debugging. Settings -> Development then check USB debugging and say yes to the pop-up.
Device Manager
Okay, I've got /Android Phone/Android ADB Interface/ in Device Manager, probably from another attempt of installing the drivers. Does that mean it's a-ok to start rooting now? Also, in ADB when I type /ADB Devices it brings up 0123456789ABCDEF.
Edit: I just looked it up and apparently the numbers-alphabet serial number is a problem. I'm going to uninstall the drivers and start fresh.
Edit 2: I'm a bit paranoid about uninstalling it, I'm going to wait for further advice to do anything.
Edit 3: I previously installed the PDANet ADB drivers, I'm going to uninstall them.
Edit 4:I pm'ed dolorespark and he said just go on with it, but it says Access denied for ADB shell. What now?
Edit 5:I was using an old and/or corrupted version of adb. It's all good now. Beginning root process.
Edit 6:Another problem, at step 3 I get an error(system/bin/sh: In: not found), anyone know what the heck is up?Last edited by AndroidPizza; 10 December 2012, 17:32.AndroidPizza
Originally posted by rvmclaughlin View PostHere is where I am at now. I have google play, the rotation is not working, it is off 90 degrees. I installed the explorer app. looked at the build.prop file and edited on the tablet. Everything I typed was in one line. It did not fix the rotation issue.
Originally posted by AndroidPizza View PostEdit 6:Another problem, at step 3 I get an error(system/bin/sh: In: not found), anyone know what the heck is up?
Found an All in One utility that works perfectly!!!
Ran across this utility, http://forum.xda-developers.com/show....php?t=2066041 it worked perfectly. This guy is a genius! Rooted, installed Play Store, I was even able to use gmail and google voice :-). Plus its actively being developed. Only problem right now is some applications don't show up on the market. I can't download netflix for example through the play store :-( TeODH4 did provided a link to http://apps.evozi.com/apk-downloader/ which seems to work just fine, but I'd like to have play store support. :-( I've already tried all kinds of build.prop mods and nothing works...
Originally posted by LoonyFreash View PostRan across this utility, http://forum.xda-developers.com/show....php?t=2066041 it worked perfectly. This guy is a genius! Rooted, installed Play Store, I was even able to use gmail and google voice :-). Plus its actively being developed. Only problem right now is some applications don't show up on the market. I can't download netflix for example through the play store :-( TeODH4 did provided a link to http://apps.evozi.com/apk-downloader/ which seems to work just fine, but I'd like to have play store support. :-( I've already tried all kinds of build.prop mods and nothing works...
There are currently 1467 users online. 2 members and 1465 guests.
