polaroid ptab8000 8" ics tablet. got su, but cant get market on it
PTAB8000 Bricked?
So, I tried to install the 2.1b release for my PTAB8000 located here: http://forum.xda-developers.com/show....php?t=2066041. When I rebooted holding down the volume - key and power, I got a message saying it was upgrading, then the screen went black. Since then, I haven't been able to reboot the thing. When I connect it to my Win7 PC, It identifies the device as an M3-Chip. I have tried to update the driver for M3-Chip with various drivers I have found on the android site as well as this forum, but nothing seems to make this thing show up. When I go into adb and list devices, nothing shows up.
Any thoughts?
Originally posted by lynchburg25 View PostSo, I tried to install the 2.1b release for my PTAB8000 located here: http://forum.xda-developers.com/show....php?t=2066041. When I rebooted holding down the volume - key and power, I got a message saying it was upgrading, then the screen went black. Since then, I haven't been able to reboot the thing. When I connect it to my Win7 PC, It identifies the device as an M3-Chip. I have tried to update the driver for M3-Chip with various drivers I have found on the android site as well as this forum, but nothing seems to make this thing show up. When I go into adb and list devices, nothing shows up.
Any thoughts?
If you're feeling adventurous, or if you don't have anything to lose, I'd do this:
- Download the PMID800 firmware here: http://www.southerntelecom.com/polar..._4.0v1_OTA.zip
- Follow the instructions for the PMID800 found here (If the PTAB8000 doesn't have the same buttons as the PMID, let me know-we might be able to find a different combo that will work): http://southerntelecom.com/polaroids...e_pmid800.html
If this *does* work, you just cracked the nut I was looking for to make a modifed stock image for the PTAB8000/PMID800
Thanks for the reply. I did download the firmware for the PMID800 and tried to run through the instructions. When I press and hold the home button and insert the mini USB, nothing happens (step 20 in the link you provided). LiveSuit can't seem to find the device, I would assume. I tried to use the Power button instead of the home button, as well as power button and volume -, but neither worked.
Originally posted by elektrik View PostNot necessarily. We might be able to get you back up and running-I just noticed on that XDA page that he says "This software is designed for the PTAB8000, and PMID800" which makes me wonder if they're indeed the same hardware (Polaroid has done this before with the PTAB7XC and PMID 703C).
If you're feeling adventurous, or if you don't have anything to lose, I'd do this:- Download the PMID800 firmware here: http://www.southerntelecom.com/polar..._4.0v1_OTA.zip
Originally posted by lynchburg25 View PostThanks for the reply. I did download the firmware for the PMID800 and tried to run through the instructions. When I press and hold the home button and insert the mini USB, nothing happens (step 20 in the link you provided). LiveSuit can't seem to find the device, I would assume. I tried to use the Power button instead of the home button, as well as power button and volume -, but neither worked.
- Press and HOLD the HOME button (do not release).
- Insert the USB cord into the tablet (while holding HOME).
- Quick-press the POWER button 3 times (still holding HOME).
- Quick-press the VOLUME UP button (still holding HOME).
- Release the HOME button.
Originally posted by elektrik View PostOk, so I looked at images of your tablet and it looks like my 703c. That middle button on the front of the tablet-did it work as a 'home' button? If so, try the following sequence:
Originally posted by lynchburg25 View PostNo dice. The button did act as a home button prior to bricking.
Originally posted by elektrik View PostIt may already be in a funky state. without the tablet being plugged in, hold the power button down for about 20 seconds.
- Press and HOLD the VOL+ button (do not release).
- Insert the USB cord into the tablet (while holding VOL+).
- Quickpress the Power button three times.
- Wait for the following screen to appear.
- Release the VOL+ button.
Originally posted by elektrik View PostIf THAT doesn't work, do the above and then try this sequence:
Originally posted by lynchburg25 View PostNeither of those sequences did anything.
Not sure what else to try, since I don't actually have the device....
Don't throw it away though-keep trying to get it into "FEL" mode-it's just a matter of trying the right sequence...
(It's so hard trying to troubleshoot devices I don't already own lol!)
Re: polaroid ptab8000 8" ics tablet. got su, but cant get market on it
Sent from my Motorola Atrix HD using Xparent Green Tapatalk 2AndroidPizza
Originally posted by AndroidPizza View PostDid you have an external SD card with a zip file on it inserted in the tablet? My guess is that it tried to load it up, thinking that it was a ROM. But anyway, why were you rebooting & holding volume -? Polaroid AIO doesn't require and rebooting or flashing anything.
Originally posted by elektrik View PostI was having them try to get intoFEL mode because ai wanted to see if they could flash a live suite image (killing 2 birds w/1 stone). if they can, I can modify a similar live suite image for a different Polaroid tab....that was where I was going...
Originally posted by AndroidPizza View PostI have a PTAB8000, I'm willing to do some testing for you, I would love to have your Elektricity ROM on the PTAB.
To be clear, I would only look at a modified ROM on your device(s). I want to be especially careful with this device, as it's the *only* Polaroid device that is 'restored' by loading a zip file onto the SD card. Makes me concerned when even Polaroid hasn't allowed it to be flashed the 'standard' way as the other tablets...
There are currently 2412 users online. 1 members and 2411 guests.
