for flash mode set-up. connect the tab to pc via usb. Use a high quality cable. The usb ports on the back of the pc are often mentioned as being more reliable, I use a laptop so cannot comment.
power down the tab. Now hold vol + pressed and then press and hold power for 3 to 4 seconds, release power and release vol +. This should start the tab in flash mode, the screen will be blank. Hopefully your PC will detect the tab and you can install the drivers from my ROM kit.
Good luck
