New 900supersport 1.1 cube U30GT H ROM
    Re: New 900supersport 1.1 cube U30GT H ROM
    Thanks for triying, take it you have gone back to the 1.6 kernel.
    900Supersport
    freaktab developer
      Yep.... reverted back....
      J.
        Hey Supersport any luck getting you Cube usb repaired? Did it break because it was low quality or were you tinkering?
          No not fixed, I'm finding useful as a tablet and am loath to send it off for a few weeks for an attempted repair than may break it.
          I take full responsibility for the damage myself, it's had a hard life being dropped onto a wooden floor from two to three feet on a number of occasions.
          Brian
          900Supersport
          freaktab developer
            Ah ok well maybe the damage is deserved Do you personally have any issues on your device that you haven't been able to find a work-around? Mine is arriving soon as an xmas present for my mum so after I install your ROM and a load of films I won't be arround to babysit the OS.
              About the only issue I have is that if I don't use it for 12 hours or so I have to turn the wireless off and back on to re-establish connection.
              Speaker is weak but OK. If I want more volume I connect an external speaker.
              900Supersport
              freaktab developer
                I don't have the WiFi issues you describe but I flashed the WiFi fix posted earlier and my WiFi always reconnects after waking.
                Sent from my U30GT-H using Tapatalk 2
                  [QUOTE=ceptic;30333]I don't have the WiFi issues you describe but I flashed the WiFi fix posted earlier and my WiFi always reconnects after waking.
                  Sent from happens with intermittent use. If I use a few times a day I have no issue.
                  900Supersport
                  freaktab developer
                    NEW MEMBER
                    Would like to say Hi as new member\&agree with earier post \ i tried all angles with Wi problem until loading 1.1cube rom with fix that has sovled whatever bug was in software .(It was after setting my cube for 3G with DONGLE THAT THE PROBLEM AROSE) Well many thanks to 900 supersport for a great rom.
                      I am currently using your 1.0 ROM and when it is sleeping it says storage unexpectedly removed and then goes to sleep again. But when it is awake it never does that. I have both of your ROM's downloaded and was wondering if I need to swap out the kernels because nobody has it working. I also don't want to lose all my apps and data. Please tell me what I need to do.
                        The SD card thing sounds like a fairly standard rk3066 issue with far formatted SD cards.
                        You do not need to flash the kernel for my 1.1 ROM. You will loose your maps an data by flashing, so backup first with something like titanium backup so you can restore later. Be certain to make a copy off the tab before flashing.
                        Hope this helps
                        900Supersport
                        freaktab developer
                          What format do you have you SD card in?
                            I use ntfs, Mich more reliable, nor supported by clockwork though
                            900Supersport
                            freaktab developer
                              Thanks for the rom Mate,
                              appreciate your hard work.
                              is this a stable release for everyday use?
                              thanks.
                                I have been using this since its release with no issues so yes I'd say it was stable enough for everyday use. IMHO until we get kernel source code these should be relatively stable builds as there are imposed limits to the tweaks and changes that can occur cf with other ROMs (eg CM).
