MINIX Forum "Community Edition" Kitkat 4.4.2
Changelog;
- recovery/OTA fix
- static ip bug fix
- video player/hls fixes
- security vulnarability fixes
- init.d support
- camera brightness fix
- freeze after uninstall app fix
- HDMI patch for DRM apps
- DDR optimalisation ( not overclock )
- Multi user support ( not fully working yet )
- Dual input devices frees/crash fix.
- new kernel logo
- etc.
Our team has been working hard to make it an awsome rom.
The work was mostly based on stability and bugfixing.
Download link:
MD5 checksum: 5FF7874FBE1CE8F1B9576467B63F06FC
WARNING!! WARNING!! WARNING!! NOT EASY TO GO BACK TO 4.2!!
(You need to use RK flashtool, do not try to flash it like an OTA update.zip !)
Available Updates:
X7 CE v2.0.0 - root update
X7 CE v2.0.0 - unroot update
X7 CE v2.0.0 - VPN Fix
To install rename the downloaded file to update.zip and place at the internal flash drive root or USB stick root, android will find the update and request you to install.
From the MINIX Forum Developers Team;
@gufone
@KAR
@HardwareGuru
Support and updates on the MINIX Forum:
