Comparing is just a matter of taste and needs. Its a very personal thing.
MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.0.0 )
Re: MINIX X7 KitKat 4.4.2 CE ( Community Edition 2.0.0 )
Originally posted by Fedur View PostCan you make 720p kernel too?
quick question
i finally! was able to get my minix x7 into flash mode. i had to take the board out of the box to make sure the usb was getting proper connection. but i'm excited to try a new ROM finally. quick quesitons tho before i continue. . .
i'm on finless 1.8 the disclaimer at the beginning about going back to 4.2 has me a lil concerned.
first. the new rkflashtool provided in the rom download doesn't seem to have an erase nand button like the old rkflash tool did. Thoughts?
do i run this as an update?
just makin sure since i don't see anyway to do a back up
After some thought I decided to give this firmware another try and I couldn't be happier. Aside from the Hulu crash (my tv has hulu so no big whoop) and the rare xbmc crash, this has been the most stable firmware I have ever used and I have one of those crappie x7s that never worked right out of the box. I have just been hoping that someone would make a firmware like this to fix it.
So thank you to all the developers of this firmware.
Update: It worked! finally enjoying 4.4.2 on my x7. thank you to all the devs indeed!!!
Edit/Update2: So far this rom is blazing fast. Much smoother performance than i had on finless 1.8. Netflix, HBO Go, Crackle, everything streaming fine over WiFi. Haven't tried LAN yet. One small quirk i noticed; I can't get anything to play in youtube above 720. I have my screen settings at 1920-1080-60. and i'm using a 1080 monitor. is this kernel related? I've installed the latest youtube apk 6.0.1.3 or w/e it is and i'm watching videos that my phone has no problem watching in 1080
the root update worked like a charm
xposed installed fine
and my modules all seem to be working
also can't seem to change the wallpaper. w/e i choose it stays the same
EDIT: this was fixed after a reboot
im sure i'll play around and figure something out. might change the launcher and see if that helpsoverall great experience so far with this ROM!
I've tried a few different launchers (Nova, GNL, and TSF) all seem to be working quite well. However, I'm unable to change a particular Wallpaper setting. Normally in android when i set a wallpaper i'm presented with a Crop Photo screen, and usually a setting for (stretched, tile, or center) modes. All my backgrounds appear to be zoomed way in on the center. With no way to change it makes quite a few of the backgrounds unpleasent to look at.
anyone else run into this problem? maybe someone did and has possible workaround?Last edited by unlo; 09 December 2014, 18:38.
hello everybody,
i was with qs3.1 and wanted to test this one; a good rom and fast rom to stay with.
im using an apk named "TV d'orange" for french tv. This apk is ok with différents phone or tablet even my old modded mk808 but all under jelly bean; but under kitkat i have a black screen and error code from apk (this code = not functionning in fact).
if anyone is using this apk, thanks for help or idea.
Have reported this issue a few times along with others and asked for any updates from the devs, unfortunately falls on deaf ears.
I know they're always very busy so maybe you'll have better luck asking in the official minix forum for help on this matter.
I believe they're releasing a new OTA Rom update sometime soon so maybe it'll resolve these issues.
Originally posted by HardwareGuru View PostThere will be an update soon. But not much regarding hls for that release. It will include a lot of other fixes though (audio/wifidisplay/sensors/rkexplorer/vpn/bt/networking/etc)..
With regards to HLS, if its of any help in the future if you have time, the 4.4.2 Kitkat Rom in the following link below works fine with plently of HLS based apps I have tried like Hulu Plus etc etc.
I so far havent found any kitkat rom the works properly, if at all apart from this one which is for a rk3066 dual core MTK chipset device but maybe it can be dissected for a fix/solution.
I've also been following these links with regards to the screen blackout issues with HLS and Kitkat 4.4.2 which is obvioulsy a known issue with the base rom.
If I find anything further or a possible fix to this issue, I'll share here and the minix forum.
There are currently 1977 users online. 0 members and 1977 guests.
