model number, and it says eFun and Nextbook all over the package in
several places. So...same Brand, different market. Maybe the NX stands
for the american market while EB refers to the european one? It's
manufactured in March 1015, SerialNr is YF03150****
I believe the NX is short for Nextbook, but I suppose it could be a code for North America.
I have no idea what EB stands for, but you could be correct about it standing for European something.
I have also noticed that they sometimes add letters to the product names/numbers to indicate special builds for exclusive retailers such as WM for Wal Mart.
Next8HD8G last year in august or september, you actually did help me
recover from a softbrick, and TWRP was working on THAT tab without
problems even despite of the different hardware IDs.
I think the recovery was actually compatible with most, if not all of them, but some models required different hardware drivers for the screen or wifi.
now, so even if I softbrick one of them, recovery should be possible using
the rom taken from the other.
it's a first step in the right direction.
There isn't much to be gained from my ROM other than my splash screens, full ADB access and init.d support.
Few people need full ADB access except developers. Most don't need init.d scripting support either, and it can be added in other ways anyhow.
up on the rockchip tools and learn how to use those for a backup. That's
something for Saturday and Sunday.
the resized partitions patch might not work, at least TWRP would be
VERY nice to have.
Just make sure you have a backup of the stock recovery and flash TWRP by itself. I would use either the Rockchip flash tools or a flash tool from the play store before trying my installer.
Then if it doesn't work perfectly, you can use either the rockchip flash tools to flash the stock recovery back, or boot into android and use a flash tool from the play store to flash the stock recovery back.
Also, be careful not to wipe the entire device or the parameter file using the Rockchip flash tool... that would be difficult to fix, though not impossible.
ShaunMT
P.S. When you get a backup, upload it somewhere and send me a link. I can take a look and try to compare it to my ROM and advise if I see any compatibility problems or not.
