The parameter mods require the system partition to be moved to a new location. The install process is supposed to backup the existing system, repartition the internal memory, then restore the system from backup. Occassionally, the backup and restore seems to fail for various reasons. When this happens, all you need to do is reflash the .zip version of my ROM with TWRP. That should install a new clean system for you and keep the current parameter mod that you previously flashed.
ShaunMT
