The patch installer only works in TWRP. The installer handles everything, it backs up the current system, changes the size settings, reboots, formats the new partitions and restores the system partition... but if anything goes wrong, like running out of space on the external sd card to back up the current system, or failing to restore the system partition, you will get the "no OS" error again...
If that happens, reflashing the .zip version of my ROM with TWRP should fix it.
ShaunMT
