Finless 2.0 ROM for the Minix X8/X8-H
    OK folks with the Official release of 002 from Minix, time to make a ROM
    This package contains the ROM and a lot of other goodies I always supplied in my tweaker kits. So now you get a full ROM and some patchers for doing other changes I did not want in the ROM itself. See the readme.txt as always or read the features listed below.
    Enjoy!
    _________________________________________________
    Features of my Finless ROM 2.0
    1) This erases NAND /data so YES you lose all data! Sorry I must do this for clean up!
    After much testing and making the changes I have, I must erase as the crap left over is not good to have! To make sure you have the best experience with my ROM, it must be erased. So sorry BACK UP your stuff please...
    2) It roots the ROM properly.
    Let me tell you Rooting on Kitkat in the ROM itself gets harder all the time to do it correctly and not using scripts! Once again due to changes with SuperUser and SU with SELinux, it was more difficult to root the ROM so it did not need to update the SU binary on firt boot! Enjoy...
    3) It debloats the ROM of all those pre-installed APPS. This includes Airplay and Minix XBMC!
    The reason I removed them is because Minix XBMC may still have bugs and some don't use airplay at all. I have given you those two APPs in a folder called Removed_Apps in this Zip so you can install them yourself if you like. The other APPs I removed you can get from Google Play. They will be updated versions anyway. Minix in my opinion should not be pre-installing old versions of APPs. It just makes a mess of a new flashed system.
    4) I removed useless system apps.
    5) I updated what APPs are left including Google Play and all the Google framework.
    As of this release, everything is updated so when you logon to Google Play nothing needs updating.
    6) Installs a cleaned up the AOSP launcher and puts more useful things in the doc bar.
    7) I give you a TWRP recovery! Yes this flashes a TWRP recovery to NAND.
    However, understand how recovery works.
    If you put a recovery.img on External SDcard the box will boot that recovery instead of TWRP in NAND.
    In this package I give you a stock recovery flasher. This ZIP will install the stock recovery to NAND if you don't want TWRP.
    Or you can open this zip and you will see recovery.img.
    Just copy that out and put it on SDcard anytime you want to use the stock recovery instead of TWRP.
    See the README in the recovery folder for more details.
    8) I set the default settings to allow non-market APPs.
    Now when you go to install a APK you wont be forced to go into settings and turn that on. I personally hate that
    9) I unlocked the hard coded device ID in boot.img. You can now spoof different devices editing build.prop. REMEMBER THOUGH, if you spoof something other than a NEO-X8 or NEO-X8-H, Minix XBMC will not work. In the ROM I left the device as a NEO-X8-H but I also give you build.nexus which you can use if you like. Just use EX File Explorer, turn on root, set system as mounted RW and rename these as you please.
    But see below for an easy way
    10) I give you build.prop spoofer ZIP updates in this download!
    One will switch build.prop to emulate a Nexus 10.
    The other one will switch you back to a NEO-X8-H.
    You can use these back and forth and they do not erase anything!
    Please note: You may want to clear the cache and data on the Google Play Store, Google Play Services after switching!
    To do this, go into settings/apps scroll over to ALL and click on each and clear cache and data.
    You know you did it right if the next time you run Google Play it asks you to accept terms.
    11) Minix unlocked the low CPU frequency scaling and the governor type.
    Thus my old CPU Fix patches are no longer needed as you can now use CPU control APPs.
    However I did find something that could be better tweaked for CPU control and that is default and max CPU scaling.
    So I supply you with one CPU patcher to fix those and allow them to "stick" when set.
    See the README in that folder for what it is and does and how to use them!
    12) Did a little "theming" this time. Hope you like it. Also Themed the Metro launcher
    13) Other tweaks and mods I do for my ROMs.
    14) Updated the boot logo to show if your booting up in 1080 or 720.
    DO NOT just copy this download ZIP to SDcard and expect it to work!
    UNZIP it and read the README for instructions!
    ROM -> Minix Neo X8 - Finless 2.0 ROM (452 megs)
    Enjoy!
    merci bob
      Download it now and Will try it later, thans for the quick action...
        READY TO MOUNT !!!
        Hi BoB, thanks for this release (I found some bugs .... it seems the original V2 release scratches the external SD card ..)... anyway, now I prefer to install yours, it will be more reliable as sure!!!
        GiG
          I am not sure what you mean here? Scratches?
            Great work.
            But some (maybe noob) questions:
            Maybe it's handy to:
            - post screenshots of the modifications
            - and show us which tweaks you have done?
            Is it possible to automate some installs with your rom? that I can modify a folder and put some apk's in it that automaticly installs? (handy for the installation of 2 boxxes of mine and my friend and brother :P)
            Which xbmc is the best version to use? a kodi one?
              Thanks for your rom I've had mk 808, mk 908, x7 and now x8h and love your roms . Don't know how you find the time to do all that you do for the devices I have owned and the ones I didn't , just wanted to say thanks.
                Holy Moley!
                You da man! I'm downloading right now and will report back later... But I know it'll ROCK!
                  Thanks for your fast and hard work!!!
                  Since the rom is different (but seems similar in many ways), could you consider releasing a custom rom for the X8-H Plus, as minix just released the stock firmware for this model?
                  thanks a lot!
                    rembo, you would need to know how to modify the ZIP update package.
                    There is a folder in /system called preinstall. Put any APK's in there and on first boot after flash it would install these.
                    You can also copy files in there using ES file Explorer and then do a factory reset and on next boot it will install them.
                    ntux, Minix is sending me a X6 and a X8-H Plus so yes I will od a ROM for those when I get them.
                      will this ROM be able to detect the exact location? The last ROM wasn't able to detect my location and I could not use the TNT, FOX Sports Go, or NBC Sports app.
                        Kodi 14 rc1 has audio but no video
                        So I installed the official 002 software and installed the new kodi 14 rc1 ...when I play any HD I get black screen with audio would ur ROM fix this issue?
                          Thank You
                          Just wanted to say thanks, Bob. As always, this is an excellent release and so much easier to update than the approach Minix took for their 002 OTA update since we can use our SDCards instead of USB...
                            Installed it without problems, SO many thanks.
                            1 little point.... the red letters when booting up .... , but thats personal.. has nothing to do with your marvelous work
                              Another masterpiece
                              Just loaded 2.0 on my MINIX Neo X8-H and all is good. I have to say that what ever you did in this rom really worked wonders on my MINIX M1 remote. So far it is very fluid and is not hanging up on me at all, like it should have been from the start.
                              Thank you again for your outstanding work.
