or firefox or flashflox
Finless 2.0 ROM for the Minix X8/X8-H
Originally posted by payright57 View Post
or firefox or flashfloxBugs are Sons of Glitches!
JustMe
thanks to Finless Bob for another great ROM
one small issue that may be related is that SSH Droid doesn't seem to function correctly with this ROM but did with minix stock firmware 2. It fires up but looses the server connection also immediately.
Not a problem as a I fond an alternative ssh server that worked OK, just wondered if maybe something you took put Bob caused the issue with SSh Droid
thanks again for your great work
Originally posted by frederick_99 View Postthanks to Finless Bob for another great ROM
Originally posted by Finless View Postcan you pull a logcat after running SSH Droid. I cannot think of anything I did that would at all mess with that? Logcat should tell us something.
thanks for taking the time to reply....
have just installed the previous version of SSH Droid ( v 2.1.0) I had from a backup and that works fine.
Yesterday i just installed the latest version 2.1.1 from playstore after installing your ROM in which developer has tried to add support for android 5, guess he broke something along the way !
I'm happy to leave as is for now
Originally posted by Genem View PostCan someone check the working temp please (with CPU temp from the playstore), when playing an movie? Mines got a bit high (to 83c). And you can feel with your hand the box runs hot.
On both my 8-h systems.
Thanks in advance.
Best to all,
R
Originally posted by micr0n View PostI seem to have issue using the k400r with this rom. I'm able to put hit the power button to put the unit to sleep, but it looks like I can't seem to wake it up. Is anyone else having any issues with this?
Originally posted by Finless View PostThis is a problem on EVERY Minix ROM or otherwise since about mid-June last year. Minix calls it deep sleep.
High CPU use and temperature
A while back I posted about high cpu use. Had one person confirm. I have 3 units and the all do the same thing. One cpu core runs at 100% all the time. On the finless rom and the new stock one as well. Does someone have any idea what I can do t fix it? Version 1 of Bob's rom does not have this problem.
Problem with high temperature is probably caused by an ir. module wich is included in the new fw.2. As soon there is no airmouse connected the system keeps intensive scanning for the missing signal. Thats why the core2 stays almost 100% all the time and the temp rises to high. As soon as the airmouse is connected, the tempo stay normal.
hope they fix it before the ota update.
is it something Finless can fix too?.
There are currently 2543 users online. 0 members and 2543 guests.
