Finless 2.0 ROM for the Minix X8/X8-H
High CPU use Finless 2 for Minix X8H
First, thank you so much for all you do Bob. Amazing,
Any idea why there would be constant cpu use of 26% it seems it is the android system itself. Did the same thing on the new stock version as well. Your ver 1 ROM didn't do this. I have 3 units and it does the same on all of them. I double checked it's not an app running. Pretty sure its the Android system itself. It looks like cpu 1 is running at nearly 100% all the times. The others fluctuate properly. Thanks for any help you can offer.
Originally posted by midiman View PostFirst, thank you so much for all you do Bob. Amazing,
Regardless, many thanks once again Finless Bob for all your help as well as for sharing all your great ROM builds etc.. You're too kind! Cheers!
Best to all,
R
Display Problems 720/1080
Hi Bob,
First of all let me offer my thanks for all you do.
I have used your roms for S89 since the first one and find it brilliant.
I onlygot my minix 8-h last week and came here immediately to get set up with your rom.
Now for the "bad" news!
The only issue is have is the same display issue which happened with first s89 rom, that display issue between 720 and 1080, causing the picture to shift off to the right, thereby losing some of the picture.
You brought out a fix for the s89, forcing it to boot into either 720 or 1080 which worked perfectly.
I'm wondering if you could possibly do the same for this rom?
Or maybe it's already in there? If so could you please give me directions as to how to set it up?
If it helps any the rom seems to boot into 1080 by default but my tv seems to prefer 720 (i had no issues on stock rom)
Bob, thanks so much again, i really appreciate your time, any suggestions would be fantastic.
Best wishes for the holidays too
Hi again Bob,
I seem to have stumbled upon a fix for this, perhaps you could let me know your thoughts?
I can, in the display settings, force the screen to display into 1080/60hz.
I tried this (after trying every other setting and rebooting about 10 times!) and it works perfectly!
I'm assuming you know all this! and were going to suggest it anyway! but if you can offer any suggestions then i'd appreciate it.
Thanks again!
stock V2 erasing external SD Card ....
Originally posted by Finless View PostI am not sure what you mean here? Scratches?
oh yeahwith my stock V2 version, using in the meantime miu-torrent and Titanium backup .... I loose all my backups .... aaarrrggghhh ... with all the data erased ... it should be a casual failure? or a version bug? I dont' know .... anycase, now FINALLY I'll mount your version to test it... and I'll give You all my feelings
ah, a last question: any news about adobe flashplayer or a browser plugin able to play flash movies? (I dislike Mercury, not user friendly).
Thanks BoB,
GiG
http://www.freaktab.com/showthread.php?20126-NEW-Finless-2-0-ROM-for-the-Minix-X8-X8-H
12) Did a little "theming" this time. Hope you like it. Also Themed the Metro launcher
No one has commented on your theme Bob but think it is great and a good choice of beer
Thanks again and keep the good work flowing, regards from Oz
Originally posted by allover View Post12) Did a little "theming" this time. Hope you like it. Also Themed the Metro launcher
Thank you in advance
There are currently 2547 users online. 0 members and 2547 guests.
