Finless 2.0 ROM for the Minix X8/X8-H
I have a quick question, not a complaint. Why isn't Google plus compatible with the MINIX Neo X8-H? I use this app all the time and would love to be able to use it on this device. If I recall, it worked on my Tronsmart t428.Last edited by glockman4519; 02 December 2014, 14:00.
Thanks bob for the new ROM, few, tests ;
Film 720p in ( sd card & USB ) with video player :
- MX Player v1.7.34 = stutter
- BsPlayer = perfect
- Player natif = perfect
- kodi-14.0-Helix_rc1-armeabi-v7a = perfect ... DTS 5.1 ( OK )
- wasser-kodi-1.0 = perfect ... DTS 5.1 ( OK )
Film 720p via streaming web with player :
- wasser-kodi-1.0 = perfect ... no DTS 5.1
For the rest, all seems fine functioned, it's really, a great ROM.
thank you very much, for your work ( cheers).
Guest
Hi Bob thanks for all your work.
Please can you also post a stock flashable zip of the origina 002 fw?
thanks
thanks
Google has changed Google+ and Google Music and they do not work for some reason!
I spent a couple hours trying to find out why.
So you know when you install a APP from Google Play it determines things like your SDK level, device, etc. It appears the X8 is getting the wrong version possibly because it is reporting a SDK level that this ROM is actually not! Again I tried to see if I could solve this but the logs simply do not give me enough info to find out why it just crashes out!
I am going to continue to see if I can find out what the problem is but it is not looking easy!
Originally posted by gjs999 View PostThink I saw a post that google music works using the version in the firmware and any updates screw it up , not tried it myself .
If anyone needs that APK let me know.
There are currently 2465 users online. 0 members and 2465 guests.
