I have a question, if I do full backup with TWRP of my 1.6 with apps now and then put 1.9 using PC and test things. If I have any problems, can I just use TWRP to restore the old 1.6 ROM back with all apps and settings? First Rockchip device for me, so not sure how things work...
Pipo P9 RileyROM 1.8
Re: Pipo P9 RileyROM 1.8
First of all, thanks again Randy for your great work making those roms possible.
I'm very happy with 1.7 and will download 1.8 asap. The only problem I found in 1.7 is with the WiFi standby and hopefully in 1.8 this is corrected. It would be great if someone has already tested and could give us some feedback about.
I'll update as soon as I test it
BR
Originally posted by Leathran View Post@aundp have you tested 1.8 yet? Because I also have battery drain on 1.7, haven't tested 1.8 yet but I gonna do that somewhere this week.
The 1.5 version was without the WiFi issue and the 1.6 was without the battery issue.
The 1.7 and 1.8 have both of them:
WiFi doesn't wake up
Battery is draining.
Is there any way to make a hybrid of 1.5 and 1.6 versions?
I think i'm going to flash 1.6 again, you can just go back from1.7 to 1.6 right? No other actions needed?
Battery drain seems to be wifi related. If you manually shutdown wifi before going to sleep, I get like 2-3% battery drain, but if you leave wifi on (even with option to shutdown on deepsleep), battery will drain 20-30% overnight and not connect back most of the time.
So Im just manually shutting wifi down before long time of not usage, its easy with a gadget on launcher.
Originally posted by Leathran View PostWhat was the WiFi issue? And does that issue still exist in 1.6?
You just flash it - no issues with it.
There are currently 1773 users online. 0 members and 1773 guests.
