With the stock firm I hadn't the wifi wakeup issue, even though it go to deep sleep. With 1.8 I have it and it's really annoying.
Pipo P9 RileyROM 1.8
Wow...that didn't take long....hahaha.Randy
Flashed 1.8 and running nicely, but after I installed CatLog to check if the problem of SurfaceFlinger spamming logs is still there, unfortunately it is. Im suprised nobody else has noticed this or is it my device doing it somehow?
Otherwise system seems to run OK, gotta see if the wifi draining battery while sleep is still there and do other tests...
I have a WIFI only version .
Had lesser problems with the 1.6 ROM, with 1.8 I see sometimes a reboot while I am doing nothing with the tablet and the battery is not bad but not as good as with the 1.6 ROM. Nop problems here with deep sleep and WIFI.
These are no complains just to share mmy experiance with the builder from the rom.
Originally posted by bytetemplar View PostFlashed 1.8 and running nicely, but after I installed CatLog to check if the problem of SurfaceFlinger spamming logs is still there, unfortunately it is. Im suprised nobody else has noticed this or is it my device doing it somehow?
Otherwise system seems to run OK, gotta see if the wifi draining battery while sleep is still there and do other tests...Randy
Re: Pipo P9 RileyROM 1.8
Originally posted by rrileypm View PostSurfaceFlinger is an Android system service, responsible for compositing all the application and system surfaces into a single buffer that is finally to be displayed by display controller. It's supposed to be there.
My P9 (16GB) arrived a couple of days ago and it exceeds expectations. Of course I immediately installed RR1.8 and apart from the deep sleep/wifi-drain bug it works great.
BUT (I'm Dutch so I'm not happy unless I can complain about something) it came with this cover: http://www.banggood.com/Ultra-thin-T...-p-949825.html and the smartcover function is driving me crazy (even more than I already was). The P9 turns on when I close the lid (but never when I open it) and when I flip it to the back the slightest movement makes the P9 turn on or off. Is there a (hidden) setting somewhere to turn the smartcover function off or do I have to physically mutilate the cover by cutting out the magnets (DIE STUPID COVER! DIE!)?
There are currently 5119 users online. 1 members and 5118 guests.
