Pipo P9 RileyROM 1.8
    Has this occurred with previous versions of my ROM? 1.7? 1.6?
    The best solution is to revert back to one your language works with. There's very little difference between the ROM's, anyway.
    Randy
      It started with the original shipped Rom oance succeeded to get factory restore and then until flashed your ROM 1.8 nothing could be done.... As switched from Eglish to other language "Power OFF" - "Power ON " UI goes down. Never tryed 1.6 , 1.7 .... Please links for download and try. Thanks a lot, Michael.
        Originally posted by JohnDen View Post
        Thank you so much Riley! :-) Clear and much appreciated. :-) But what originally puzzled and still puzzles me is that I actually don't know if this PiPO P9 *is* a 3G or WiFi only tablet. ;-) So THAT actually should have been my question. ;-) Sorry and thank you very much again. :-)
        If your P9 is having a slot to put in a SIM-card it is a 3G otherwise it is a WIFI.
          Ok, thank you so much. That is what I needed to know. I thought that MAYBE a P9 with support for 3G dongles STILL is sort of a 3G PiPO. This one definitely has not a SIM card slot. So WiFi it is. Thank you for your patience. :-)
            Originally posted by Grumpert View Post
            My P9 (16GB) arrived a couple of days ago and it exceeds expectations. Of course I immediately installed RR1.8 and apart from the deep sleep/wifi-drain bug it works great.
            BUT (I'm Dutch so I'm not happy unless I can complain about something ) it came with this cover: http://www.banggood.com/Ultra-thin-T...-p-949825.html and the smartcover function is driving me crazy (even more than I already was). The P9 turns on when I close the lid (but never when I open it) and when I flip it to the back the slightest movement makes the P9 turn on or off. Is there a (hidden) setting somewhere to turn the smartcover function off or do I have to physically mutilate the cover by cutting out the magnets (DIE STUPID COVER! DIE!)?
            Hi, I have the same cover then you. And... I had to remove the magnets because they were making me so angry by turning off my screen
              RileyROM 1.6, 1.7
              Can NOT find links for RileyROM versions 1.6, 1.7
              having "systemUI stopped working" problem on right to left languages Arab/Hebrew with version 1.8...
              Please help with the links .
              Thanks.
                Is in Archived pipo Roms. Not Current Pipo Roms.
                Gesendet von meinem GT-I9300 mit Tapatalk
                  Thanks R4Sh
                  Thanks R4Sh
                    Sorry to repeat a question, but Riley.. do you know what file and how to edit in the /etc folder to increase the gain of the inbuilt microphone for Skype usage, its a good 30dB too low.
                      I haven't seen it...but I can take a look.
                      Randy
                        You might try adjusting the numbers in /etc/asound.conf.
                        Sent from my P9
                        Randy
                          Sent from my P9
                          I did try that one, the header of the file gives a description of parameters and value ranges, but it talks about 2G3G/voice calls, nothing mentioning general OS use. I did just have a go and turn them all up, no difference.
                          There are 3 or so files all with same sets of options in them, so I was wondering if there is a specific file needed to do the job, and perhaps the three in the etc folder are generic ones or for other optional chipsets... as all 3 files look to be essentially the same options, perhaps refered to by alternate audio drivers?
                            You might run a dmesg log and see if the driver is listed. That may narrow things down.
                            Sent from my P9
                            Randy
                              There is a new Stock ROM for Pipo P9.
                              Possibly only change is to support alternative hardware. New flash chips.
                              New hardware means factory has pushed out new massproduction batch with new mainboards and flash chip got revised. Usually supply & price causes changes.
                                Here we go again with multiple versions. We went through this with the M9 Max and the M8 Pro. Don't expect the new firmware to work on the already released versions until we do some testing....otherwise there could be a rash of bricking a perfectly good tablet.
                                Sent from my P9
                                Randy
