Cube T9 64bit octacore A53 4G beast.
Updates in English?
I got an English (australia) ROM, its offered me five updates, will wireless update update to English, can't find change log sometimes I get cannot connect error in camera , great tab otherwise maybe it will last long enough to run a 64 bit app is built like a tank goes like a sports car
Originally posted by Riddick View PostI found some screenshots that was done to show English speakers what to press. Seriously you just press the most obvious. There is only one big green button, to kick off the process.
Do you have a link to the screenshots? i done some Google ...could not find.
Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View PostIt might be obvious to some, but I tend to be overly cautious!
Linux halwa king root
Dmmit how to paste lol wait for blue bar and click it seems after green
I think imma wait a bit but at least, well even chrome wouldn't let me open some rooters so make sure is real site
Originally posted by balvan64 View PostUpdate on Aliexpress dispute regarding the defective device:
They send me a letter in Russian, only problem is I'm not Russian...
I used Google translate and I found out they are telling me the problem was that I didn't unlock the screen, and I should unlock it....Are they just acting stupid or what?
"добрый день,
просим прощения за доставленное неудобство
мы только что показали поставщику ваше видео,они задали вопрос,на видео видно что вы только нажали экран,а правильно использовать, надо сдвинуть, чтобы разблокировать экран
попробуете пожалуйста сдвинуть экран,если ешё появилась проблема,сделайте новое видео пожалуйста,потом мы попросим поставщика разобраться как можно быстрее
ждём вашего ответа
с уважением
катя"
Yes, it says here that you should've unlocked your screen and generally that you should be sliding along the screen and not pressing it in certain points.
What is the video that they are mentioning?
What is exactly the issue that you are having?
One has to bear in mind that the touch screen responsiveness has a lot to do with the configuration of the scheduler of Android, so maybe we just have to wait for an update of the os.
Nevertheless I think it's an awesome tablet for the price. I would like to compare it to an iPad in terms of performance, I think it wouldn't stand a chance.
Good night!
Just tried it again ...let it run for 20 min. No go!
Thanks for the info ....
Originally posted by zdun8 View PostYes, it says here that you should've unlocked your screen and generally that you should be sliding along the screen and not pressing it in certain points.
Good night!
Originally posted by BamaPanda View PostIf you are referring to the one done with an apk in tablet, already tried.
Once it was done I used another app to verify whether it was successful. I used an app called 'root checker'
Also I knew it worked because busybox installed and so did titanium backup.
What I am currently stalling on now is the installation of clockworkmod/rom manager. I haven't read anywhere about anyone doing it successfully. I have however read somewhere that twrp won't work.
the current OS build from what I have read is quite new and unique. Can someone please remind me of the name.
BTW I no longer have any screen sensitivity issues. I am also using SwiftKey and it's fast.
Originally posted by f1c View PostI linked the video in the previous post:
Get into factory test mod y mode (Vol - + Power button while device is off) and then follow the video. You will just have to pause and count down down which menu he goes into since it's all going to be in Chinese.
Pressing vol+ and power enter in a menu with 4 options:
Recovery boot
Fast boot
Normal boot
UART boot
That's all. Very different than the video.
Fast charge?
Anyone have found some information about Cube T9 fast charge solution?
I see in description something like "5V/2A charging and 9V/2A fast charging. It can be fully charged by 9V/2A charger at 1,5H/3,5H".
Only available information I have found about this new feature is here "The updated Quick Charge is available as a stand-alone circuit, and could drive even laptops demanding up to 60W of energy" and a compatible charger is one of these.
If this is the same thing, it might be an awesome feature for T9 ~3 hours for a fully charged battery vs. 6,5 hours for Talk 9X is great.
Another test made for my nonworking touchscreen:
I've enter to Settings>Developer options>Pointer location.
On the top of screen appears some data.
P:0/1 is the points I'm pressing. For example, 4 pressing points with four fingers = P:4/4
When I press with my ten fingers, only detect 5-6-7 points. Never 10/10.
Sometimes only detects 3 or 4 points.
So... I have a problem.
I've tested it on my LG G3 phone and my Onda V989 and Ifive Air and it detects 10/10. So the T9 is not detecting the pressing points.
Originally posted by Hekatombe View PostAnother test made for my nonworking touchscreen:
I suppose you have a badly connected touchscreen .. send to warranty/factory.
Tomorrow I will get my T9 and I'll post some videos on Y!T about this if your problem persist.
Originally posted by Edius View PostTry this https://www.youtube.com/watch?v=n90u8xsY5UQ
Originally posted by Riddick View Postdo not use the apk, it doesn't work tried it a few times. As I mentioned before you must use the pc version of King root.
That was what I downloaded at the start ...still on my PC. Still do not know Chinese, tho!
Any hints on that?Cube T9; Pipo M8 Pro (on life support); LG gPad
There are currently 3860 users online. 0 members and 3860 guests.
