Cube T9 64bit octacore A53 4G beast.
My Cube 9X (5 months old) was sold yesterday for ~235USD and I just bought a CubeT9 on Aliexpress with case and DHL delivery for 275USD.
I think it will reach me next Friday.
I'm on this camp now.
I see here a few owners but I have not read about T9 pluses and minuses.
It was some kind of buying blind.
Originally posted by giouncino View Postroot = ability to have administrator rights (install and use Titanium backyìup, faster GPS, greenify and ALL apps requiring rooting access, possibility to delete some chinese stuffs and so on), it's really usefull
OTA update (if the other term is this) = install the latest stock rom via Over The Air (OTA) updates, Stock Roms are always NON rooted.
If I am able to root the T9, keeping the stock ROM. ...will the OTA update feature mess up the root if used?
ThanksCube T9; Pipo M8 Pro (on life support); LG gPad
BamaPanda,
I don't think so...
but who knows?if you appreciate my efforts this is the link for any donation:
Act fast for the best price
It may not last long, so if anyone is thinking of the T9 ...go to
http://www.geekbuying.com/item/Cube-...te-339140.html
You have to registered, but once registered ...use the code 0109LV.
It brings the tablet down to 223 and some change. It is 260+ elsewhere ...mostly 279.00 up.
WOW!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by freakboy View PostThat was what I was trying to find out as I am still on 1.03 and everytime i check for OTA, it says I am already on latest firmware.
You might send a text to Cube, and see what they suggest. Hope the tablet is ok otherwise.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by kzeele View PostUghhh I can't decide between the cube 9x and cube t9. I know T9 is better but its 80 dollars more for me than the 9x.
My prices are in CAD
Cube 9x $171
Cube T9 $254
That's the only thing hold me from buying the T9
Have you checked with geekbuying and actually placed the code in to see how low it would go to in CAD?
I have an iPad II, and the T9 gives the impression of being much closer to the overall speed and quality of that tablet (actually faster in some areas).
I do not recall having that same impression with the 9X (although the X at that time was the best I had seen from China).
I wish you well.Cube T9; Pipo M8 Pro (on life support); LG gPad
BamaPanda, to be honest you should say that about overall buil quality, talk 9x is a little bit better than t9, but I agree with you that t9 is faster!if you appreciate my efforts this is the link for any donation:
Cube 9x $171
Cube T9 $254
I had the same problem. But the difference was 30 USD, not 80. And I bought T9.
Originally posted by giouncino View PostBamaPanda, to be honest you should say that about overall buil quality, talk 9x is a little bit better than t9, but I agree with you that t9 is faster!
I see the build quality on the T9 as top notch ...no issues what-so-ever. One can have a sightly thicker tablet, and still have excellent quality.
It may be that we have a different perspective on what makes up build quality.
If you are considering being thinner as a part of the quality equation, then the 9X would have an edge here ...but to me that is not to be considered in build quality.
Bottom line, they are both built about as good as anything I have seen out of China ...better than most anyone ...and pretty much equal in the overall quality.
There are currently 1743 users online. 0 members and 1743 guests.
