Cube T9 64bit octacore A53 4G beast.
Originally posted by hammerjoe View PostI have a question about the Gps.
Does it require a Sim card to function properly?
Install fasterGPS can improve use of GPS on rooted devices.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostThe answer is no: GPS can work without wifi and without SIM. To faster fix the satellites for the first time it is suggested to enable wifi/or sim card.
BTW, CES 2015 is about to start, do you think there will be new stuff worth to consder against the T9?
I don't know, but you can wait and see, at least the T9 price could reduce a little bit more.
Thank you.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by hammerjoe View PostSo what is the situation about grainy screens with CUBE and for the T9?
Is this still an issue with the T9?
It must be a situation for a few, but not the majority. Giouncino said he got 5 later version 9X into his office, no problem.
Hopefully with the T9, Cube has got the QC issues connected with this corrected.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View PostI should have mine by mid week. I will report back.
Where did you get it?
I am really surprised that I am not seeing more reviews about this chipset MTK8752 and for the T9 in particular.
Maybe theres more action with the Chinese language?
Originally posted by hammerjoe View PostThank you, I cant wait to read your review.
I got mine from geekbuying.com, but the price has now gone back up.
Still too new for a lot of true reviews in English.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View PostPlease go back and read posts 117-119 in this thread.
As I can see on Y!T, T9 have an outstanting boot time( 14-15").. with approx. 40% shorter than 9X.
I hope Mediatek has solved issue with battery stuck percentage issue on this tablet...and maybe some working NTFS/exFat drives.
If these annoying glitches are solved, my 9X will be sold and buy T9 for me and a (upcoming)T8 for my daughter.
I'll wait for your honest opinion.
Originally posted by Edius View PostI hope to see a true and detail review about this tablet, with pluses and minuses.
I do not recall seeing the mentioned issues with the 9X I had. Give me a bit more detail on what to look for, especially the NTFS/exFAT issue.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by Edius View PostI hope to see a true and detailed review about this tablet, with pluses and minuses.
On cube talk 9x:
The battery stuck problem is no more present with latest patch
NTFS is working for me tooif you appreciate my efforts this is the link for any donation:
Some time ago I let tablet on idle for ~4 days with 60% battery ... after that guess what .. battery still on 60% but after 2 hours on Youtube has sudden shutdown at ~40%.
I think it will be ok to leave it switched on overnight and check battery on morning .. will be fine to decrease 2-3% in 8-12 hours.
Cube 9X does not knows to use NTFS and exFAT format to access files larger than 4 GB (720p or 1080p movies) .. would be enough if you format a microSD card in NTFS and in exFat format and check if it is recognized.
There are currently 2566 users online. 2 members and 2564 guests.
