Did several tests and they are all in the 35000 range.
Cube T9 64bit octacore A53 4G beast.
BamaPanda,
I agree with you, once you have a good performance tablet that you can verify every time you use it, what's the matter with antutu score??
Enjoy using your very good Cube device and leave antutu scores alone!!!if you appreciate my efforts this is the link for any donation:
It could be the cause for dropped score under Antutu.
By the way only the user can be sure it's ok or no ... not Antutu.
The best way is to test with a game or two you know, and the feeling under some circunstances of the game. I suggest a game I think it's the more voracious in terms of computing.
Originally posted by tonas View PostTry test the sensors because before 1.07 many didn't work or not software implemented.
The best way is to test with a game or two you know, and the feeling under some circunstances of the game. I suggest a game I think it's the more voracious in terms of computing.Cube T9; Pipo M8 Pro (on life support); LG gPad
asphalt 8 need a great GPU power for exampleif you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View Postasphalt 8 need a great GPU power for example
@ Bamapanda @ Hammerjoe :
The suggestion of Giouncino or one you know well.
Another idea there is a gesture configuration where you can tap 3 times for a zoom, I was having troubles whit it while playing piano : there were lags ... unplayable, only pressing one key at a time !
Originally posted by tonas View PostYou can try another game. Usually under Google Play there is a few suggestions when you search a software.
One thing I remember with my T9 and Antutu the 3D scenery was smooth contrary to Talk 9x. Check it.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View PostI have a few loaded and they have all done very well ...no issues. Just curious how the T9 might handle a demanding game like Asphalt 8.
Originally posted by greebly View PostFor those that have updated to v.1.07 any reports? Has it eliminated the reboots on v.1.06?
I think I can tell when it feels like it might ...as something might have a momentary freeze ...but then it let's go, and does what it needs to!
The only time I think it might be threatening to reboot ...or lock up, is when I try to open some videos in Dolphin.Cube T9; Pipo M8 Pro (on life support); LG gPad
There are currently 2442 users online. 0 members and 2442 guests.
