Cube T9 64bit octacore A53 4G beast.
    Just got my T9. Love it, but surprised by battery drain. While sleeping overnight about 5 hours, it drained from 100 to 89%. The WiFi was on.In 30 min of light use, has drained 5%. Is this normal? Do I need to fully discharge then recharge the battery a few cycles first?
      Batteries in these tabs seem to get better with bit of use. After a couple of recharge cycles from at least 20%, it should stabilize and improve.
      I assume you have upgraded to the latest software.
      Congrats on your new tab!
      Cube T9; Pipo M8 Pro (on life support); LG gPad
        Check in Settings/Location, is possible to have GPS ON.
        I did some battery drain tests in idle time few weeks ago and results are these:
        - WiFi only when connected/4G mobile connection/Data ON - 4% in ~ 9 hours idle time.
        - Wifi only when connected/4G mobile connection/Mobile Data OFF - 1% in ~9 hours idle time.
        - WiFi always ON/4G mobile connection/Mobile Data ON - 2% in ~ 9 hours idle time.
        - WiFi only when connected/3G mobile connection/Mobile Data ON - 4% in ~9 hours idle time.
        - WiFi only when connected/3G mobile connection/Mobile Data ON/Restrict background data -3% in ~ 9 hours idle time.
        Choose what setting fit your needs and pay some attention on email accounts sync frequency (GMail is a battery drainer if account sync is set too "tight").
        During usage is have ~ 10% battery drain using UC Browser HD with flash enabled in 65 /70 minutes with minimum screen brightness (Chrome and Dolphin browsers are more battery hungry ~ 50/55 min/10%)
        Playing some 720p movies with default video player takes ~ 10% battery in 65-70 minutes (BS Player with SW Decoder gives ~ 55 min. and MX Player with SW decoder ~ 50 min./10% battery..... HW+ decoder mode (more battery friendly) won't be enabled on MTK based devices ).
        I don't recommend to fully discharge battery, you won't get any good results on that and charge controller could be damaged.
        Cheers, Edy.
          Originally posted by Edius View Post
          ..........I haven't seen this...truth is I used camera only few times.
          This behaviour is observed using default camera app?
          I use both the default and google camera.... exactly same result...i dont think its the app.. I think It has something to do with the ROM...but then again since I'm the only one having this issue it might be factory defect.. But for now the camera works but it won't be long before it crashes again.....
            Can we flash Cube T9 with Teclast t98 kernel (with 2 ghz cpu) Will it brick my tablet.... Any news on how to increase the 2gb app partition on the internal nand flash. By the way I'm quite happy with this Tablet so I ordered a new T9 coz I contacted Cube and they told me that they can't provide a new or spare inner LCD at the moment........ Therefore, I'll have a lot of spare parts for my new T9...eh! ..... silver lining after all...
              Hi
              I wanna know if this 9V-2A charger could be compatible with our Cube T9?
              Aukey® USB Turbo Charger Qualcomm Quick Charge 2.0
                Originally posted by Rolon View Post
                Hi
                I think is compatible.
                I haven't read about anyone here or elsewhere to use one of these. Asked myself some time ago about quick charge here
                Talked with one guy from 4PDA about this and she ordered one of these...no feedback about this until now.
                Originally posted by gixer View Post
                ....... I ordered a new T9 coz I contacted Cube and they told me that they can't provide a new or spare inner LCD at the moment........ Therefore, I'll have a lot of spare parts for my new T9...eh! ..... silver lining after all...
                Why you didn't buy one of these ? I'm 100% positive this is the screen type for T9.
                This is T9 LCD picture found on web (pretty hard to see, but in your situation I have tried already). Click image for larger version
                Here is one picture with what you can see in (Aliexpress seller posted above) LCD description. Click image for larger version
Name:	T9 LCD 2.JPG
                To me looks similar with what we have in T9.
                Edit:
                here is a cheaper one http://www.aliexpress.com/item/Origi...274992249.html
                  i have ordered this tab 2 days ago from aliexpress, how long it took for you to verifie the payment?? :/
                    Also T98 have the same clock frequency of T9: 2Ghz is a fake.
                    as for talk 9x, T9 and T98 will not be stable at 2Ghz, so they are limited in the range of 1.7Ghz.
                      This is T9 LCD picture found on web (pretty hard to see, but in your situation I have tried already). [ATTACH]n492005[/ATTACH]
                      Here is one picture with what you can see in (Aliexpress seller posted above) LCD description. [ATTACH]n492006[/ATTACH]
                      Edit:
                      Thanks, but I had already ordered a new T9, and to be honest, well its probable, I mean It might be similar or completely different, who knew (with certainty), I just don't have the guts to take a risk and order one (no offense) could be a total waste of money if its not compatible...!! Anyway thanks for yor concern, really appreciate it... BTW is it too risky to use a 4 Ampere or above adapter charger...for a faster charging
                        Thanks, so 1.7 is the maximum stable frequency for mt8752, I could have sworn that I have read somewhere that T98 is clocked at 2.0 ghz.....
                        Yeah, found it, its on devicespecification.com site
                        here's the link.... http://www.devicespecifications.com/...ison/2b18202d4
                          Gixer and as I told before: this is a Chinese Fake!
                          It's really common!
                            Thanks Edius
                            Maybe I'll try the Aukey charger then
                              Hi there,
                              i downloaded Asphalt Airborne 8 yesterday, but its not playable. Its running like on 8years old device. Its going everylike but not smoothly.
                              So i checked my power true benchmarks and everything looks ok, more then 39000 in Antutu.
                              Do you have some problems with this game, maybe its not optimalised for this screen res?
                              thx
                              jan
                                prague77, it's not a matter of screen res: on my talk 9x Asphalt airborne 8 run smoothly on "medium details"(this is the default setting).
                                Talk 9x has the same screen and resolution of T9.
