Cube T9 64bit octacore A53 4G beast.
I have had the T9 for a bit now and everything works great and no grainy screen at all and battery life is very good..I have it rooted already and have TWRP installed and the only thing I noticed is when I want to backup the rom to the internal sd it does not show enough space available on the internal sd but there is plenty...so I have to save to external sd..not sure why it does not show the proper size for internal sd..but otherwise all works well.
Originally posted by fztt View PostHad it for a week now... 1.08 rooted, 1 time hang while reading got to force reboot, other than that working fine, battery after 1st full charge lasted 3 days standby plus 7.5 hours screen on usage, which included 25 min of GPS, browsing & reading, so far so good. GPS locked within 2 mins without A-GPS & data plan, impressive.
What app did you install? What else is required... such as a sim card... cell provider, etc.
I ask as I was not aware it could be free.
Thanks.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by Cyborger View PostHello, another one T9 owner hereI have some questions:
1. Do you noticed that battery temperature sensor is not working and shows always 25°C? That's weird because i think battery temp is important. My other MTK device even turns off when battery overheats on heavy usage in hot air conditions.
2. Why is so important to backup IMEI? MTK Droid does not allow me to backup(disabled button), so is it enough to write down my IMEI to text file? or there are some other must backup files?
3. Anyone tried to flash stock rom from manufacturers page? is everything ok with these files?
As I can see there is only 11 out of 22 partitions in the scatter file
Code:root@T9:/proc # cat partinfo cat partinfo Name Start Size pgpt 0x0000000000000000 0x0000000000080000 proinfo 0x0000000000080000 0x0000000000300000 nvram 0x0000000000380000 0x0000000000500000 protect1 0x0000000000880000 0x0000000000a00000 protect2 0x0000000001280000 0x0000000000a00000 seccfg 0x0000000001c80000 0x0000000000040000 lk 0x0000000001cc0000 0x0000000000060000 boot 0x0000000001d20000 0x0000000001000000 recovery 0x0000000002d20000 0x0000000001000000 secro 0x0000000003d20000 0x0000000000600000 para 0x0000000004320000 0x0000000000080000 logo 0x00000000043a0000 0x0000000000800000 expdb 0x0000000004ba0000 0x0000000000a00000 tee1 0x00000000055a0000 0x0000000000500000 tee2 0x0000000005aa0000 0x0000000000500000 metadata 0x0000000005fa0000 0x0000000002060000 system 0x0000000008000000 0x0000000052000000 cache 0x000000005a000000 0x0000000007000000 userdata 0x0000000061000000 0x0000000080000000 intsd 0x00000000e1000000 0x0000000665b80000 flashinfo 0x0000000746b80000 0x0000000001000000 sgpt 0x0000000747b80000 0x0000000000080000
5. Also as I can see MTK Droid does not support this chipset so it must be updated to work properly, anyone knows if developers working on that or if there is anything how we can help them?
dd if=/dev/block/mmcblk0p2 of=/sdcard/nvram.bin
dd if=/dev/block/mmcblk0p7 of=/sdcard/boot.img
dd if=/dev/block/mmcblk0p8 of=/sdcard/recovery.imgYou may only view thumbnails in this gallery. This gallery has 1 photos.1 PhotoLast edited by mmrrdd; 14 May 2015, 18:55.
Thanks.
Edit: Sorry, I used wifi to use google maps AFTER gps signal is locked, but to get signal lock, no sim card & no wifi...
Btw, anyone managed to permanently remove the chinese apps? I uninstalled but they always reinstall themselves after each reboot...Last edited by fztt; 14 May 2015, 16:57.
Just to confirm - already rooted, so I can just use root explorer & delete?You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Have you seen it http://www.androidiani.com/forum/tut...ml#post6709875
Repartitioning of userdata in T9...also mt8752 without EBRLast edited by hocuspocus69; 14 May 2015, 18:38.
Originally posted by mmrrdd View Postthis my thirdparty folder ,
I have replace all chinese apk with my favorite app.
Thanks! Managed to delete all with root explorer.
Discovered another annoying problem - screen get scrambled & hang every 1-2 days, got to long press power button to reboot. Anyone else facing this problem with rooted 1.08? This always happen when I'm using perfect viewer, 3-4 times already...
May I ask those who experienced random reboots before... did your tablet just reboot itself or did it hang with screen scrambled like mine?
Reason I ask is the last time I had a tablet where the screen got scrambled/display garbage & hang, it was a hardware fault, I hope this is not the case here
Originally posted by hammerjoe View PostMine after a few seconds (didn't time) but within a minute it reboots by itself.
In my opinion is the only way see if is an HW failure (bad memory or overheating CPU) or an software issue.
There are currently 2874 users online. 1 members and 2873 guests.
