linksd allows ttosimulate extra memory without messing up with system. It seems to be an easier solution
Cube T9 64bit octacore A53 4G beast.
Originally posted by hammerjoe View PostThat's too complicated for me to mess up with the system until i feel there will be no more updates from cube.
- Root prevent ota update
- Repartition prevent ota update
- Custom rom prevent ota update
In any case the repartition as well as the root solutions are completely reversible.
What is the problem?
Jeepers this was a fun afternoon.
after some problems to root the device i doesn't some time trying to install supersu (which made me install twrp) with no luck.
at the end of the day i have the tablet rubbing without loss of data with 1,gb of internal storage thanks to link2sd.
i have set up a 4gb sdcard with a 3gb partition that link2sd uses as virtual storage to ccomplement the internal storage. Shouldn't have more problems now.
Originally posted by hammerjoe View PostI instaled trwp, thanks mmrrdd but supersu still doesnt install.
Oh well, at least its rooted with kinguser.
Download and extrack to TWRP folder on ext-sdcard and then boot your device to twrp,and restore .
Kinguser never list on play store .
Kinguser and SuperSU those are same as "superuser access management tool" when you install kinguser on your device, it install another Chinese App called “KingMaster”
Many people don’t feel fine with “Kinguser” and “King Master” installed on their devices as they are unknown Apps for Android users .
The only took that was able to root my T9 was the kinguser app. Tried both desktop versions of vroot and king with no success and also the iroot app. After the root tried to install supersu and it just kept asking everyone to install the binaries. Maybe it wasn't the right version. I got it in the google playstore.
choosing the normal recovery didn't work so why ahead and installed trwp from the other topic about the T9 mods. Tried to install supersu using the trwp recovery but it would not reboot the device and go in recovery.
i then download the binary and tried to install it via trwp. It doesn't work either. I gave up and have kinguser as the root admin. Took out kingmadter asnd purify and everything working fine
another way to root you T9 factory rom
1.flash full factory firmware (v1.07) , !!! to protect you IEMI and nvram partition, select dowload mode only.
2 .boot you device and do factory reset (your device wiil boot to factory recovery and wipe any old data)
3. arter your devve reboot ,connect to wifi or internet ,and go to setting page ,then do the otaupdate to get v1,08
4. after ota process complete ,flash your recover by twrp-recovery-image
5.reboot your tab and conect to inernet and open browser , go to google.com and type" supersu 2.49 xda" ,go to target page and download supersu zip file
6.put supersu zip file at ext-sdcard ,power off your devive ,and boot it again to twrp recovery and select install > select supersu zip file > confirm
after process finished you devive will rooted by clean supersu
if you need to remove china app ,you can do by boot to twp recovery >select mount check system > return to start page > seclct file manager >
go to /system/thirdparty folder > delete all files in this folder
There are currently 2214 users online. 0 members and 2214 guests.
