Yup, you can read through from page 74 or comment #1096 onwards for those with similar problems & possible solutions to reduce the frequency of it happening by tweaking the governor parameters... mine has stopped crashing almost completely while some still crashing but reduced... forget about contacting cube support unless you're prepared to send back to China, their official response to me was "yours was the only unit with the problem, they're not aware of anyone else complaining about the same issue."
Cube T9 64bit octacore A53 4G beast.
Originally posted by zenki View PostI'm using XnetfoX eXtreme. Do I need the script still?
That depends on whether devilz-wolit incorporated into his rom and each unit is different, you might need to tweak & test until it's stable for you...
Originally posted by hammerjoe View PostWould I be able to install supersu using the flashify app by installing the binary download of supersu?
flashify can flash a backup image file to the target partition ,it can't push apk-file to the partition.
if you need to push some file directry to some partition ,boot to twrp -> select mount -> chek at system -> go back to start page
->select file manager -> copy/paste/change permission of your target file.
The cpu governor script is not there. You have to create it and put in the init.d folder with permissions 0755 (rwxr-xr-x) and reboot the tablet.
For script edit use notepad++
devilz-wolit,
Where about's the location of the init.d folder?
Do I just put int the contents of governor.zip into the init.d folder or just a script file?
If just a script file then which one do I use?
thanks
thanks
put only one governor file, modify the autorizations of file, restart the tablet and it
Hey people.
I have been watching this thread for a while since I got my T9. Nice tablet but with the usually Chinese problems. Still, I managed to fix some but the crashes are bugging me... The solutions provided here might help but I can't apply them either from the scripter in rom toolbox nor from the init.d folder. Something is wrong.
Currently I am at 1.08 rooted and I get permission denied on scripter and nothing happens on init.d folder.
I wish you well.Cube T9; Pipo M8 Pro (on life support); LG gPad
âI note I am not the only one having issues with typing... Getting the 194,160 addition
âHas to be a site issu e. I do not see it anywhere else. s.
​I am using Swiftkey.  Hmmmmmm! Cube T9; Pipo M8 Pro (on life support); LG gPad
â
âI am using Swiftkey.  Hmmmmmm!
Originally posted by Arkanovios View PostAbout the crashes, I have the same amount on all firmwares and on normal occasions such as getting down the notification bar. That's why I wanna try these modifications but it seems that I don't have the necessary permission although I do have them!
... seems like the problem is more prevalent than Cube (& their online trolls) care to admit, perhaps you might want drop them a message on facebook so that the more people are highlighting it, the less likely they can claim its isolated cases.
One shortcut I can think of, instead of troubleshooting why init.d not working for you, is to flash devilz-wolit's rom on post #1179 above since he already got it working... then test out the scripts...
There are currently 1902 users online. 0 members and 1902 guests.
