Cube T9 64bit octacore A53 4G beast.
Originally posted by zenki View PostWhen I got the tablet, it already has a protective cover on it. I'm not sure if this is the cause but when I touch the screen and plays around with it, it feels kinda jello/jellyish sensation, not rock solid.
Mine came with two plastic protective sheets on the screen The first one is to be removed; part of packing. The second is actually a screen protector. I ended up removing that as well. Your decision.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by zenki View PostHi everyone,
I just recently got the this tablet with a screen protector already on it and I have to say I am impressed with it.
However I have a few questions
1) The LCD screen feels kinda soft/flaky when I touch/push it compared to say a samsung galaxy s3 screen which is hard/solid. Is this normal?
2) Which stylus/pen works with this tablet? I got a cheapo brand which works with a galaxy s3 phone but not with this tablet. Why is that? Could it be because of the soft screen?
Originally posted by zenki View PostAfter another check, mine got a protective sheet? at the back of the tablet and a screen protector at the front for the lcd. But it's only one though, not two sheet at the front.
By removing the screen protector, won't you risk scratching/damaging the screen?
The outer plastic protector does offer some protection, but many opt to remove it for better response.
Used mine for months till it got all scratched up. Once removed, I just never replaced it. Don't like bubbles. 😊Cube T9; Pipo M8 Pro (on life support); LG gPad
Hmm I think mine got screen responsiveness issue. I've removed the screen protector and still have to press hard to be able to drag icons around. If not then the dragging may cut halfway before the destination.
Also the screen feels kinda plasticky? It create a squeal/squeaky sound when I am dragging/moving on it on purpose.
Anyone got a solution for this?
Well, I'm looking over this thread for enough time to have a real opinion.
You guys, with touch issues, must have some HW issues like grounding or something else.
Fw 1.8 is very stable for me, only one-still insolved problem- is with Firefox sync.
I was very busy on last few weeks and my T9 was pretty much on idle this time, with an wonderfull battery drain during this time (Airplane Mode ON,WiFi ON only when connected, Sync Off)...~1%/8 hours drain with this setup.
Originally posted by hammerjoe View PostWould routing the device and install the app linksd solve this problem? Or would recommend a different ram expander app?
Root not is necessary.
Here the link + procedure
There are currently 1771 users online. 0 members and 1771 guests.
