i have another issue where the auto brightness gets stuck so I definitely have a software problem.
Cube T9 64bit octacore A53 4G beast.
Battery stuck is a trick used for Talk 9x too.
Temp sensor is simply not present so they forced a fixed value.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostBattery stuck is a trick used for Talk 9x too.
i didn't notice that before.
that could explain the crashes because the battery does get hot and with no sensor to control its inevitable that the device crashes.
Yeah it seems that the T9 will never get to have LP. That's the problem with the Chinese stuff. Development is very short. They just slap a new case and a new name and make it the new flagship model.
The only hope are custom Roms but I don't know what are the chances of that happening either.Last edited by hammerjoe; 26 May 2015, 19:08.
As usual is not due to Cube, but to Mediatek that never release source code for newer android versions...if you appreciate my efforts this is the link for any donation:
I've tried fw from 1.02 all the way to 1.08 again after reading some comments here that 1.05 don't have reboot/crash problems... but didn't solve problem for mine... also tried to throttle the CPU max speed & different governors, nothing works :-( Contacting aliexpress seller for solution...
There are currently 2026 users online. 2 members and 2024 guests.
