Cube T9 64bit octacore A53 4G beast.
Originally posted by Edius View PostOn latest V1.06 not happening to have random freeze and reboots?
That's happening to a lot of us.
I have to stay on V1.05 (with no issues for over 2 weeks) and don't have any problems like you described.
Regardless, my reboot issue is pretty much gone ...and I am on 1.06.
Fingers crossed!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View Post3C Cpu Manager may have helped my reboot issue, although I am not sure I actually set it up right.
Fingers crossed!
But thats only 4 rooted device...
You are on root plus you can ota updates? I heard that rooted device can't ota update...
Or do you recommend root?
Fingers crossed!
Rolled back to FW V1.05 with no issues, everything works just perfect.
I don't remember about some improvement in V1.06 over V1.05 (nor visual , nor in touchscreen sensitivity or battery management)
I think something is changed there (certainly is another kernel, that maybe undervolt a little CPU and that give this random reboots/GPU artifacts ).
Personally I'll wait next update OTA, or why not...Lollipop.
If you do an OTA update, you DO lose the root ...but it is very easy to re-root.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by Edius View PostUsed FW V1.06 for a few days, received ~1 or 2 random reboots on two days.
LP would be nice!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by AGBOHOU View PostHello. I wonder if you got to use this Link2SD T9 tablet? I have made several attempts but Link2SD says: Unable to create the installation script. Do you have a tip to give me waiting there to be custom Tee1 and Tee2 files. Thank you for your reply.
Link2SD only works with rooted devices. I am using it and it has allowed me to alleviate the issue with the stupidly small partition given to the system partition.
Also I have found that whatever application you move with Link2SD on a reboot any settings will not apply if they are required during the boot sequence, until the unit has completed a boot. For instance, wallpaper changer, and Launcher.
Must have Link2SD, Launcher, Wallpaper changer, and any key services ( eg. digitizer ) remain on the system partition.
Originally posted by Riddick View PostLink2SD only works with rooted devices. I am using it and it has allowed me to alleviate the issue with the stupidly small partition given to the system partition.
My tablet is root but I tried everything but I always had the writing of the script error message. I desperately need more space to install my apps but alas. I have a well recognized by the tablet 256GB card.
Originally posted by VGutnik View Post
Definitely Cube has a big real problem with the T9. A lot of people with this problem. 😤I
I tested this app with my cube talk 9x: no issues at all, I'm able to use 10 fingers together on the screen!
It's so strange that with a newer model they did such a stupid mistake!if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostI tested this app with my cube talk 9x: no issues at all, I'm able to use 10 fingers together on the screen!Originally posted by giouncino View PostIt's so strange that with a newer model they did such a stupid mistake!
Rest assured if Cube had bought a bunch of bad parts, whether it be the screen or a part associated with it's function ...everyone who bought a T9 would be having the same issues.
This is QC issue with some tablets. I have been fortunate. Here is hoping the issues we have seen here are limited ....quickly coming to an end!Cube T9; Pipo M8 Pro (on life support); LG gPad
Greetings. First time tablet user requesting help.
My T9 arrive from Tmall with a microUSB keyboard case cover/stylus/OTG cable/32GG Kinsgston microSD. Supposedly rooted with firmware 1.06.
Need help with the following problems:
1. Stylus doesn't appear to work. Any suggestion for working stylus?
2. The files on the microSD (FAT32) card not recognised when using a usb card reader attached to OTG cable.
3. External microUSB keyboard not working properly. A few key on the A and Z rows missing, Backspace became z, etc. Same problem with bluetooth and PC keyboards.
All keyboards working properly when tested on other Androids.
How to rectify this problem?
4. Intend to use the T9 as a desktop, with the charger and external mouse/keyboard/usb drive/etc. Any suggestions for OTG cbale with multiple USB inputs that supports charging simultaneously?
Many thanks and best regards.
Also dont forget to calibrate the gyro sensor and reboot the device.
What app did you use to test the touchscreen?
There are currently 2909 users online. 0 members and 2909 guests.
