Cube T9 64bit octacore A53 4G beast.
Originally posted by BamaPanda View PostI imagine you are talking about screen refresh rate.
How would I check that?
E.g https://www.youtube.com/watch?v=uxwQd5LaJK0#t=112 (timecode 1:50)
If you put this video in HD, you will notice it's in HD at 60fps.
Originally posted by NFMynster View PostWhat I mean, is that the video is recorded with 60 frames per second. It is a option that some cameras have, and when you're watching video, it feels a lot smoother to watch.
The camera I want is the new Olympus OMD E-M5 MK2. Now that camera does video very well!
One day!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by BamaPanda View PostMy Olympus EPL2 does 720p video at 30 frames per second.
One day!
Originally posted by NFMynster View PostOh well, that's a shame. But well, it is incredibly fast right? No stutter on the animations between apps and such?
Fastest tablet I have ever had ...period!
I would like to hear comments about faster tabs, as I am sure they exist!Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by eexez View PostTry rileyrom and fail.. Reboot reboot. How install stock ROM ?
1. Download ROM V1.04 in your PC
https://docs.google.com/file/d/0B_9NApgkoxE-eUROYWdXblFvUnc/edit?pli=1
2. Extract archive and rename all folders in latin characters (original folder names are in chinese)...if you keep original folder names you'll get an BRom error from SP Flash Tool.
3. Power off tablet
4. Open SP Flash Tool
5. Point to scatter file and all boxes from SP Flash Tool will be populated with files
6. Select Download only mode or Firmware Upgrade mode.
7. Click on Download
8. With tablet powered off connect USB cable and you'll see progress bar working at bottom of SP Flash Tool....at 100% turn off SP flash Tool and disconnect USB from PC.
9.Change system language as you wish (default is in chinese)
10.Connect to WiFi /Go to Settings/About tablet/WiFi update/Check for updates
11.Update OTA to V1.05 and stay there (do not update to V1.06 ...that may cause random reboot)
it's an bug on V1.06...probably will be fixed on next V1.07.
Originally posted by Edius View PostFirst install drivers from here https://docs.google.com/file/d/0B_9N...MVE/edit?pli=1
3. Power off tablet
Originally posted by zdun8 View PostI didn't do anything. It has been already good when I got it. But I haven't tested it thoroughly.
What is the issue that you are having?
There have been a few here that apparently got a T9 with issues, but I would venture most are like yours and mine ...almost perfect! (Hoping they stay that way)
Best tab from China I have experienced ...hands down!
There are currently 3082 users online. 1 members and 3081 guests.
