Cube T9 64bit octacore A53 4G beast.
Originally posted by hammerjoe View PostIsn't interactive better than hotplug?
At least that's the impression I'm getting after reading about governors.if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostOn more than 4 cores processors as mt8752 and mt8392 interactive governor increase power drain and heat production because even on low workload all cores are "ready" while in hotplug mode unnecessary cores are practically switched off. I think interactive governor is not optimized for octacores, hotplug is more efficient, some developers prefer hotplug governor over interactive on 4 cores cpu too.
Where is the selection for 'hotplug'? It looks to be set at 'ondemand' right now and the CPU definitely cycles up to 1.85 when using tab.
Thanks.Cube T9; Pipo M8 Pro (on life support); LG gPad
With "cpu tuner" app you can fix maximum frequency and select the cpu governor too, remember that cpu governor can be selected only between the governors available in T9 kernel.
On talk 9x hotplug governor is present, on T9 I don't know....if you appreciate my efforts this is the link for any donation:
Originally posted by giouncino View PostWith "cpu tuner" app you can fix maximum frequency and select the cpu governor too, remember that cpu governor can be selected only between the governors available in T9 kernel.
Checked V1.02/1.03/1.04/1.05..about 1.06 already we have info's..interactive governor present in all these FW's and all report 1.859 GHz on Core0 and Core1. When CPU is on load (at least Core0/Core1/Core2/Core3 will stay in max. 1.6GHz)
Perhaps in all these FW's Cube developers are trying to optimize kernel..V1.06 maybe is too much optimized if we are looking to reported reboots.
And about touchscreen issues..are not present in my tablet.
My touchscreen works perfect in all these FW's (second screen protector was already removed).
Hello. Pls forgive me little OT.
Please help me. I have read and read and read this topic... and i have a problem with making decision to purchase the best tablet for me. I want to have very good display, gps (+glonas) and 4g (or 3g).
Which tablet will be better? Cube T9 or Teclast T98? Maybe another one? There are very similar tablets.
Maybe i sould wait to purchas newer tablet?
Many thanks for your help and advice
GPS is very good, a little more precise compared with Talk 9X.
My first GPS fix with this tablet was indoor on my balcony (1m accuracy, acquired in first 20 seconds).
4G/3G/Phone call function and mobile data transfer works flawless.
Display is very good, a little grainy but not very easily seen or noticed.
I said already is blazing fast?
I agree with Edius, Cube is generally more reliable than teclast, furthermore T98 is lighter, but for a reason: it has a 8500mAh battery wrt T9 that has 10.000mAh.if you appreciate my efforts this is the link for any donation:
Update on screen touch detection
Hi guys,
I got to say that the device has gone crazy.
I'm going to put it a side and buy Samsung or something, it is totally unusable.
It detects touches on places I don't touch. I touch point X, but It reacts as though I touched point Y, even if they are half a screen away.
60% of the times when I'm scrolling (by "draging" the screen up or down) and my finger will pass over a button, It will react as though the button was clicked. It happens so often, the device is just useless.
My GF is using it, so I didn't know about this until she showed it to me today. I tried working with it for 10 minuets and I just gave up.
The digitizer is nuts! beware!
So much for buying Chinese...
Other options from Cube with a 9.7” screen would be the Talk 9X (a true bargain for what it is) and the Cube i6 if you would like a Windows tablet that might be modded to dual boot in the future.
The i6 is nice, but does not last as long (battery) as the T9 or the Talk 9X.
The T9 I have is better than anything I have ever bought from China in a tablet, and I have had quite a few ...from Teclast to Onda to Pipo to Cube. The T9 has been the best!
If you already removed second screen protector you should consider an replacement.
My touchscreen is perfect...few hours ago rolled back to all firmwares(1.02 to 1.06) and checked this thing too and no problem has been seen.
I wish you well.Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by balvan64 View PostI got to say that the device has gone crazy.
when the charger was unplugged the touch worked well,
replaced with another charger of good quality, touch screen has always worked perfectlyLast edited by DAGO; 04 February 2015, 09:25.
There are currently 1885 users online. 0 members and 1885 guests.
