Cube T9 64bit octacore A53 4G beast.
MicroSDXC cards work... after reformat in FAT32...
Back to "newbies things"...
I've just received my 'Integral' 64 Gb microSDXC Class 10 UHS-1.
Inserted at first, it was not recognized by the T9.
I used 'guiformat.exe' I found there (I hope it's 'secure'...)
Then I inserted the card in a card reader
and formatted it in FAT32 format with my PC (Allocation unit size: '65536').
Then I inserted it un my T9, and the card was directly recognized with 59.79 Gb total available space as seen on my 'french' screenshot...
Originally posted by Hekatombe View PostIn the last days using my T9 I've had 2 or 3 system freezings and reeboots...
Anyone with the same problem? Could it be the higher cpu speed as told on previous posts?
I think is kernel fault (CPU undervolted) or something else.
This "overclock" is present in all firmwares, I've checked myself.
Is more a"fine tunning" thing .. hopefully will be solved on next days (V1.07 or why not on Lollipop)
Originally posted by hammerjoe View PostCongrats Edius for the diy and job well done.
I am not brave enough to attempt such mod and besides it doesnt bother me so I will leave it like that.
Yeah I removed the two pieces of plastic of the screen protector. I was tired of having touchscreen issues and that was the last straw before going thru the hassle of sending it back.
I only use the tablet at home so removing the screen protector is not a big deal.
I dont think that screen can scratch that easily and if you get a case then it should be well protected.
I bought mine from gearbeast at the same time as my tablet and I have received it yet... I might have to open a dispute with my cc soon.
Originally posted by hammerjoe View PostI only use the tablet at home so removing the screen protector is not a big deal.
I dont think that screen can scratch that easily and if you get a case then it should be well protected.Cube T9; Pipo M8 Pro (on life support); LG gPad
There are currently 1691 users online. 0 members and 1691 guests.
