Cube T9 64bit octacore A53 4G beast.
Generally on custom roms is better to NOT use ota updates, often developer of custom roms disabled this option by default.
Ota updates are designed and tested on stock rom, if you use ota on custom you can have bootloops or other malfunctions!if you appreciate my efforts this is the link for any donation:
Originally posted by Riddick View PostGenius, I had to go through the troubleshooter FAQ to fix the driver issue.
CWM recovery installed!!!
Update:
More fail ->
[ATTACH=CONFIG]10038[/ATTACH]
It will only populate when the device is booted. And of course the NVRAM/IMEI is greyed out.
If I boot into CWM Recovery MODE, the device is not detected by the MTK Tool. *sigh*
Update Clarification: When I select Recovery mode, after about a minute of there being a black screen it appears to then just boot normally.
EDIT: Finally I could backup NVRAM/IMEI!! But now I can't load Ssupersu binaries!! Help pleaseLast edited by Hekatombe; 25 January 2015, 20:42.
Originally posted by giouncino View PostGenerally on custom roms is better to NOT use ota updates, often developer of custom roms disabled this option by default.
All i bloody want is to install the 1.04 stock rom, and upgrade using the ota updates to 1.06, then i will do a titanium backup before rooting. Something as simple as that is turned into a gawd damn saga.
Sigh, i thought a HTC m7 rooting was hard enough, this tablet is right on par.
Originally posted by Riddick View PostWell my situation sucks a whole lot more. i thought there was standard cwm img file i could use to replace rileys custom cwm, but it appears cwm is built per device, sigh ( for some reason i thought otherwise ).
Still I dont't see how to do a Titanium Backup without Root. Titanium is Root dependent.
That's a 5 min. job.
Originally posted by Edius View PostJust flash 1.04 stock ROM (do not forget to rename all folders from .rar archive on latin characters before and select Download Only mode in SP Flash Tool) and you'll be able to update to 1.05>1.06 OTA.
Btw Edius, I don't quit understand the renaming requirement. Can u elaborate on this point. I vaguely remember it being mentioned in other posts but I can't remember the specifics.
Cheers again for your assistance.
Originally posted by BamaPanda View Post
Although I think it's iRoot at version 2.08 or something.
Originally posted by Riddick View PostYep, that's the tool I will use this time on the stock Rom, especially seeing its in English and there is a unroot option.
Is there a difference? Version 2.08??Cube T9; Pipo M8 Pro (on life support); LG gPad
Originally posted by maxecume View Post...still waiting for my touchscreen to be better...
(sorry for my bad english)
I'm sure understand what is the cause of the malfunction of the touch screen, it is not the screen protector or the bad quality of the touch but ...... THE BATTERY CHARGE !!!
when it is connected the touch works badly (see image ....)
when it is disconnected the touch works perfectly ....
now I use a Samsung charger 5V - 1.0A .....
charging is slow but when connected the touch works well !!!
I'll try to do other tests with different chargers
I hope this can be useful
<snip>
The supplied charger creates high frequency electrical interference which upsets the touch sensor during charging. I examined the charger inside; it seems safe enough but not as good quality as the tablet itself.
I now use Samsung 2A charger which is excellent quality and creates no problems.
[ATTACH=CONFIG]10049[/ATTACH]
[ATTACH=CONFIG]10048[/ATTACH]
Sorry to bother you, rooting experts... I let you at your explorations... ; )
There are currently 2903 users online. 0 members and 2903 guests.
