The multitouch test in Phone tester gave me a 7 fingers score.
Cube T9 64bit octacore A53 4G beast.
Hi guys, I can't belive what is happening!!
This morning I've turned on the T9 and updated it to 1.06 because last night i read that there was a new firmware (1.06).
I updated, and tried the sensitivity of the screen... BAD.
Then I've made a hard reset and tried again... The same results... Bad touchscreen sensitivity. Same problem as the first day of use of the T9.
But this morning I DON'T shut off the tablet. I leave the tablet ON (I always shut off the tablet when not using it).
After the day of working, I arrived at home and take the tablet again... I can't believe it!! It seems that the sensitivity problem disapeared! Like magic! I' m writing this with swiftkey keyboard without any problem!! I'm very excited and confused at same time.
I don't understand whats happening, but it's GOOD!
But I really have not done anything. Only left the tablet ON for a day and nothing more.
I'm surfing the intenet without any problem, installed some apps, writting on other forums, played Fruit Ninja, etc... and all is ok.
Originally posted by Hekatombe View PostIt's late night in Spain and I go to sleep. I'll shut off the tablet and charge it all night. Now the battery is very low.
I hope tomorrow all goes well like now.
I'll keep you informed.
Let's hope your own problem is solved....
You could see on my "kids paint" pictures,
that sometimes it works for me, ans sometimes not at all...
Let's hope for a "magical healing" or maybe 1.07 which works...Last edited by maxecume; 24 January 2015, 02:42.
Originally posted by maxecume View PostT9 at its best....grrrrrrrr....
[ATTACH=CONFIG]9981[/ATTACH]
Nice lines.
Peel that shitty screen protector and enjoy your T9.
Really..if you want to save screen from kids scratches take one with some quality..like Vikuitti (made in Germany) or something with some references.
Originally posted by Edius View PostNo man...that's one nice picture.
Nice lines.
[ATTACH=CONFIG]9982[/ATTACH]
With @Edius, I am realizing that it is maybe that 1.20 USD screen protector which upsets...
I don't want to have a "naked" screen so I quickly order a Vikuiti Talk 9x screen protector on Amazon.
It seems to work better with naked screen and screen heat is maybe a parameter, too but it is so randomly...
Originally posted by maxecume View PostGuys, it's 2:30 am in France and I'm a bit tired...
Note I said two (2) layers on the screen ...one throwaway, and one that is supposed to stay, as it is an actual screen protector SMOOTHLY, efficiently applied!
I will peel all these layers back one day, and use nothing but the glass screen. I will not worry, for the touchscreen is GLASS, not plastic like many of these cheaper tabs use. It will hold up well, and well NOT get the etchings and lines that plastic always will.
So don't worry! We have a glass screen, not plastic ...and that is GOOD!Cube T9; Pipo M8 Pro (on life support); LG gPad
It seems to work better with naked screen and screen heat is maybe a parameter, too but it is so randomly...Cube T9; Pipo M8 Pro (on life support); LG gPad
Here's a test ROM for this tablet.
It should work, OK...but I don't have a T9 to test.
Randy
This ROM is based on v1.04 which the site said was a fix to the touch panel. Hopefully this will make a difference for all of you having those touch problems.
Just be careful...I would like to have an experienced flasher attempt this the first time. That way I won't have to talk a hundred people through fixing a problem if flashing goes wrong. As we get reports of good results, we can open the gates....and I'll start a new thread for this ROM.Randy
Originally posted by rrileypm View PostThis ROM is based on v1.04 which the site said was a fix to the touch panel. Hopefully this will make a difference for all of you having those touch problems.
I was getting nervous and I didn't even raise my hand!Cube T9; Pipo M8 Pro (on life support); LG gPad
There are currently 3216 users online. 1 members and 3215 guests.
