Please I need a link to the tools
Unbrick or fix NAND on the MK808
Originally posted by asdkgh View PostPlease I need a link to the tools
Mask Rock Usb
Originally posted by fratello View PostTry change : the USB port, the cable, the power adapter, the PC ...
tried to change the usb cable also.
I've noticed a new detail:
On the Flash tool bottom, the "No Found RKAndroid rock usb" change to "Found RKAndroid MaskRom Rock Usb" when i plugged my mk808 using the 8-9pin short on the NAND chip.
What does "MaskRom" mean?
How do i change it to "Loader Rock" as i belive requierd following the instruction on the readme file.
dude.
When in MASK ROM mode you are in unbrick recovery. Just erase NAND and flash the ROM now.
Originally posted by Finless View PostWhen in MASK ROM mode you are in unbrick recovery. Just erase NAND and flash the ROM now.
INFO:Start to erase NAND
ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=542,nSendBytes=12288,dwT otalSended=1241932
Your having USB communication issues. Bad cable, make sure your using a USB 2.0 port not a 3.0, do not go through a USB hub, etc etc... Also some of the power supplies provided are junk and can also cause issues like this.
Originally posted by Finless View PostYour having USB communication issues. Bad cable, make sure your using a USB 2.0 port not a 3.0, do not go through a USB hub, etc etc... Also some of the power supplies provided are junk and can also cause issues like this.
I didn't get that from your instructions.
I understand that you should plug only the OTG port and the unit get the power from that.
Should I plug the power supply?
USBBoot failed
Originally posted by Finless View PostIf your sure your PC can supply enough power then no you dont need the power supply.
INFOownload USBData OK
ERROR: DeviceIoCOntrol failed.
ERROR: Download USBBoot failed.
Why USBData ok but USBBoot dont?
There are currently 1669 users online. 1 members and 1668 guests.
