Unbrick or fix NAND on the MK808
    Tnx, but I tried everything... Changed three cables and four PC, and always I got same result: "Download boot fail" or "Erasing IDB failed". I give up
      Same here. I bought it from DX and was dead from the beginning. I did everything I found and nothing. I guess I had bad luck. Not sure if I would take the chance to order another one even if it looks one of the best out there.
      Thanks much to Finless though.
        Originally posted by natxito View Post
        Thanks for your help.
        I think all of us appreciate your efforts and work.
        Jose Ignacio.
        As Jose said, once again thanx....
          New ideea : You used "ROM Flash tool" (or "RKBastchTool.exe") as admin ?!?
            Getting the same issue as others in "MaskRom" mode.
            Here is the log:
            04:10:31 554 Finless ROM Flash Tool - RKAndroidTool v1.3.5.0 Start Run
            04:10:31 555 Scan thread:5528
            04:10:31 557 Infothread=5620)IoControlProc-->DeviceIoControl In
            04:10:31 559 Infothread=5620)IoControlProc-->DeviceIoControl Out,ret=1,err=183
            04:10:31 561 Infothread=2396)IoControlProc-->DeviceIoControl In
            04:10:31 562 Infothread=2396)IoControlProc-->DeviceIoControl Out,ret=1,err=183
            04:10:31 564 ProcessID:4584,ThreadID:6100,RefCount:0
            04:10:31 566 ProcessID:4584,ThreadID:5528,RefCount:0
            04:10:31 568 ProcessID:4584,ThreadID:5620,RefCount:0
            04:10:31 576 Infothread=5600)IoControlProc-->DeviceIoControl In
            04:10:31 578 Infothread=5600)IoControlProc-->DeviceIoControl Out,ret=1,err=183
            04:10:31 584 Infothread=7084)IoControlProc-->DeviceIoControl In
            04:10:31 679 Infothread=7084)IoControlProc-->DeviceIoControl Out,ret=1,err=183
            04:10:31 682 Infothread=2672)IoControlProc-->DeviceIoControl In
            04:10:31 685 Infothread=2672)IoControlProc-->DeviceIoControl Out,ret=1,err=183
            04:11:28 051 INFO:Start to erase NAND
            04:11:33 109 ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=4096,nSendBytes=0,dwTota lSended=1635076
            04:11:33 112 ERRORownload USBData failed
            04:11:33 116 ERRORownload boot failed
              I did all things from this topic, but when Im flashing device, program gives me error "Download IDB failed". Any idea how to fix this ? Please help.
              Log: http://pastebin.com/85gE6LJm
                Try to uninstall, then re-install RK drivers ...
                  I did it and again same error. I have 2 devices. One of them work and I flashed on it new ROM without problems.
                    I think your other device has a bad NAND chip. A user here sent me a UG802 clone with the same problem. It cannot write low level NAND so it is bad.
                      Theres no chance for repair it ? When I run it first, I saw android loading logo for long time. I decided to reset device and it never run again :c
                        My log says:
                        13:29:59 562 Load Setting ok
                        13:29:59 593 Finless ROM Flash Tool - RKAndroidTool v1.3.5.0 Start Run
                        13:29:59 593 Scan thread:1340
                        13:29:59 593 Infothread=1488)IoControlProc-->DeviceIoControl In
                        13:29:59 593 Infothread=1488)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                        13:29:59 593 Infothread=1928)IoControlProc-->DeviceIoControl In
                        13:29:59 593 Infothread=1928)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                        13:29:59 593 ProcessID:1292,ThreadID:3876,RefCount:0
                        13:29:59 593 ProcessID:1292,ThreadID:1340,RefCount:0
                        13:29:59 609 Infothread=2320)IoControlProc-->DeviceIoControl In
                        13:29:59 609 Infothread=2320)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                        13:29:59 609 Infothread=168)IoControlProc-->DeviceIoControl In
                        13:29:59 609 Infothread=168)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                        13:30:02 593 INFO:Start to erase NAND
                        13:30:07 687 ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=4096,nSendBytes=0,dwTota lSended=1241932
                        13:30:07 687 ERRORownload USBData failed
                        13:30:07 687 ERRORownload boot failed
                        13:30:11 687 Info:wait for exiting scan thread start
                        13:30:11 890 Info:wait for exiting main thread start
                        13:30:11 890 ProcessID:1292,ThreadID:3876,RefCount:0
                        Just to confirm:
                        Does this log mean that my NAND is damaged too?
                          "Erasing IDB failed!"
                          I've been lurking here for a while... mainly to get advice on which device is (would be) better - settled for an MK808.
                          Finally my MK808 arrived this Tuesday. I have tried the original firmware for the first couple days to see how it was (not bad - expected worse). Then flashed finless 1.6 and the problems started: Lots of hangs and crashes. (I not saying it is 1.6 fault though)
                          Today it finally stopped working. There's no other way to get it recognized but shorting 8-9 pins.
                          I'm getting these messages in logs (tried erase and also flash):
                          00:48:29 581 Load Setting ok
                          00:48:30 409 Finless ROM Flash Tool - RKAndroidTool v1.3.5.0 Start Run
                          00:48:30 409 Scan thread:4980
                          00:48:30 409 Info: (thread=5900)IoControlProc-->DeviceIoControl In
                          00:48:30 424 Info: (thread=5900)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                          00:48:30 424 ProcessID: 284,ThreadID:720,RefCount:0
                          00:48:33 269 ProcessID: 284,ThreadID:4980,RefCount:0
                          00:48:33 285 ProcessID: 284,ThreadID:5900,RefCount:0
                          00:48:37 411 INFO: Start to erase NAND
                          00:48:42 692 INFO: Download USBData OK
                          00:48:47 755 ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=4096,nSendBytes=0,dwTota lSended=1635076
                          00:48:47 755 ERROR: Download USBBoot failed
                          00:48:47 755 ERROR: Download boot failed
                          00:49:30 975 Info: wait for exiting scan thread start
                          00:49:31 022 Info: wait for exiting main thread start
                          00:49:31 022 ProcessID: 284,ThreadID:720,RefCount:0
                          00:54:14 425 Load Setting ok
                          00:54:14 503 Finless ROM Flash Tool - RKAndroidTool v1.3.5.0 Start Run
                          00:54:14 519 Scan thread:4140
                          00:54:14 535 ProcessID: 2064,ThreadID:4084,RefCount:0
                          00:54:14 535 ProcessID: 2064,ThreadID:4140,RefCount:0
                          00:54:14 550 Info: (thread=4128)IoControlProc-->DeviceIoControl In
                          00:54:14 550 Info: (thread=4128)IoControlProc-->DeviceIoControl Out,ret=1,err=183
                          00:54:15 941 INFO: Start to erase NAND
                          00:54:21 020 ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=4096,nSendBytes=0,dwTota lSended=1635076
                          00:54:21 020 ERROR: Download USBData failed
                          00:54:21 020 ERROR: Download boot failed
                          00:54:23 956 MaskRom Device Path(\\?\USB#VID_2207&PID_300A#5&1A915965&0&1#{a5d cbf10-6530-11d2-901f-00c04fb951ed}),threadID=2824
                          00:54:23 956 INFO: Start to run
                          00:54:23 971 INFO: Start to download boot
                          00:54:29 034 ERROR: DeviceIoControl failed. bRet=1,err=0,dwReturnByte=4096,nSendBytes=0,dwTota lSended=1634496
                          00:54:29 034 ERROR: Download USBData failed
                          00:54:29 034 Error: Download boot failed
                          00:54:29 034 ERROR: MaskRomThread failed
                          00:54:29 049 ERROR: Run failed
                          00:54:51 341 Info: wait for exiting scan thread start
                          00:54:51 607 Info: wait for exiting main thread start
                          00:54:51 639 ProcessID: 2064,ThreadID:4084,RefCount:0
                          Also tried official tool:
                          00:49:55 976 Rockchip Batch Tool v1.5.3.0 start run
                          00:50:13 447 **********Upgrade Start Total<1>**********
                          00:50:13 447 <Layer 4-1> Download Boot Start
                          00:50:18 527 <LAYER 4-1> ERROR:Boot_VendorRequest-->DeviceIoControl failed,Total(12390),Sended(0),bRet(1),err(0)
                          00:50:18 527 <LAYER 4-1> ERRORownloadBoot-->Boot_VendorRequest471 failed,index(0)
                          00:50:18 527 <Layer 4-1> Download Boot Fail
                          00:50:18 527 **********Upgrade Done Success<0> Fail<1> Time<5079>ms**********
                          Tried 4 USB cables, 3 laptops + 1 desktop (win7x64+winxppro+win7x32) might not have made all the combinations, though.
                          I'm lost. You still think it is a USB communication problem?
                            Finless, we need your help.
                            Most of us having the same issue and even golden-plated USB cables do not help.
                            Bring us some more ideas please!
                              Re: NEW - Unbrick or fix NAND on the MK808
                              i read somewhere from bob its maybe a locked bootloader.
                              si for safety always uncheck bootloader in the flashtool.
                              he is working on it.
                              Verstuurd van mijn GT-S5660 met Tapatalk
                              if you love my work please buy a coffee
                              <form action="https://www.paypal.com/cgi-bin/webscr" method="post">https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
                              </form>
                                RKflashTOOL
                                Has anyone tested this linux tool? (it seems a previous user already posted he did)
                                It is quite "old" but it is said somewhere that RK30(66) is also supported with some tweaking.
                                @finlessbob: could you give pointers on this? At least the writing addresses and sizes for all the stuff needed to be flashed? Or, if possible, at least the one (file, writing address and size) needed for the device to boot again?
                                Right now i'm overloading with work to investigate and test this shortly...
                                EDIT:
                                More info on RKFlash and RK30 platform:
