Unbrick or fix NAND on the MK808
Lourenço...LOL
O problema é que a luz azul acende...e apaga-se logo.
O unico "erro" que detetei ao longo de todos os flashes foi que nas instruções sempre diz que após carregar no botão de reset duas coisas deviam acontecer:
1) O pc reconhecer o device - OK
2) A luz apagar-se ao entrar em modo reset. Isto nunca acontece...O PC reconhece o device, mas a luz azul nunca apaga quando o stick está ligado ao pc via porta otg...isto é esquisito.
Ontem desmontei o stick e chantei os pinos 8+9 da NAND, o pc reconheceu...mas a p*ta da luz azul fica sempre acesa.
Só está acesa qd não preciso lol...
probably it is better to keep writing in English as it may be against forum regulations (?).
Mine doesn't turn on the LED at all. In fact, the first and only time I flash it I had to put it in the flash mode (pressing the hidden button that is, in fact, a VOL+ button - LOL - I wonder where is the VOL-) when it should have been recognized out of the box.
The unit still switches the HDMI HUB (5-port) in my TV setup but noting on screen.
Did you installed the driver correctly? (you should have a RK30 device in device manager) also, it seems that these devices are very sensible to the PC/USB ports - did you tried on other PCs? - I know I have (netbooks, notebooks, desktop PCs, ...) - also, try other USB cable (a branded one like SONY, LG, ... maybe with a ferrite core) the usb cable shipped is most probably crap.
In your case I believe that you're going to be able to flash it. (hopefully)
Tonight I'll uninstall the driver and I'll start (again) from the beginning.
I notice that RockusbDriver.zip (link in apad.tv) could be different from Finless driver package.
So I'll start again, but always with a doubt on my mind...wtf is GV20 ????
The flash tool shows no errors so I doubt seriously this is a ROM flash issue. What the issue probably is, is you dont really have a stock ROM for this and none of the other ROMs will work on this unit.
The Process from the begining...
18:56:58 883 **********Restore Start Total<1>**********
18:56:58 904 <Layer 5-8> Download Boot Start
18:57:01 352 <Layer 5-8> Download Boot Success
18:57:01 421 <Layer 5-8> Wait For Maskrom Start
18:57:02 972 <Layer 5-8> Wait For Maskrom Success
18:57:02 984 <Layer 5-8> Test Device Start
18:57:03 026 <Layer 5-8> Test Device Success
18:57:03 041 <Layer 5-8> Check Chip Start
18:57:03 056 <Layer 5-8> Check Chip Success
18:57:03 072 <Layer 5-8> Get FlashInfo Start
18:57:03 085 <LAYER 5-8> INFO:FlashInfo: 0 0 0 1 0 10 10 18 1E 4 1
18:57:03 104 <Layer 5-8> Get FlashInfo Success
18:57:03 122 <Layer 5-8> Prepare IDB Start
18:57:03 141 <LAYER 5-8> INFO:CS(1) (8192MB) (MICRON)
18:57:03 191 <Layer 5-8> Prepare IDB Success
18:57:03 207 <Layer 5-8> Download IDB Start
18:57:03 988 <Layer 5-8> Download IDB Success
18:57:03 997 <Layer 5-8> Reset Device Start
18:57:05 006 <Layer 5-8> Reset Device Success
18:57:05 019 <Layer 5-8> Wait For Loader Start
18:57:07 493 <Layer 5-8> Wait For Loader Success
18:57:07 507 <Layer 5-8> Test Device Start
18:57:07 522 <Layer 5-8> Test Device Success
18:57:07 536 <Layer 5-8> Lowerformat Device Start
18:57:20 558 <Layer 5-8> Lowerformat Device Success
18:57:20 568 <Layer 5-8> Test Device Start
18:57:20 578 <Layer 5-8> Test Device Success
18:57:20 629 <Layer 5-8> Check Chip Start
18:57:20 638 <Layer 5-8> Check Chip Success
18:57:20 648 <Layer 5-8> Get FlashInfo Start
18:57:20 654 <LAYER 5-8> INFO:FlashInfo: 0 0 0 1 0 10 10 18 1E 4 1
18:57:20 663 <Layer 5-8> Get FlashInfo Success
18:57:20 672 <Layer 5-8> Prepare IDB Start
18:57:20 677 <LAYER 5-8> INFO:CS(1) (8192MB) (MICRON)
18:57:20 694 <Layer 5-8> Prepare IDB Success
18:57:20 707 <Layer 5-8> Download IDB Start
18:57:21 199 <Layer 5-8> Download IDB Success
18:57:21 208 <Layer 5-8> Reset Device Start
18:57:22 218 <Layer 5-8> Reset Device Success
18:57:22 228 <Layer 5-8> Wait For Loader Start
18:57:24 535 <Layer 5-8> Wait For Loader Success
18:57:24 551 <Layer 5-8> Test Device Start
18:57:24 566 <Layer 5-8> Test Device Success
18:57:24 580 <Layer 5-8> Download Firmware Start
18:59:11 159 <Layer 5-8> Download Firmware Success
18:59:11 312 <Layer 5-8> Reset Device Start
18:59:12 336 <Layer 5-8> Reset Device Success
18:59:12 395 **********Restore Done Success<1> Fail<0> Time<133506>ms**********
...the same result...DEAD
Finless, where can I find a stock romm for this ?
@diniscampos : Did you see this topic : http://www.freaktab.com/showthread.p...8No-Wifi-BT%29 ?
Your model seems to be a "MK808B Fake" ...
Originally posted by fratello View Post@diniscampos : Did you see this topic : http://www.freaktab.com/showthread.p...8No-Wifi-BT%29 ?
Mine has 2 internal antennas, like my photos...
Originally posted by diniscampos View PostHi fratello, thanks for your answer, but min dont have an external antenna.
Originally posted by l0ur3nz0 View PostNo you're looking wrong at it - no external antennas. At least your seems to be one of the first units. In fact, initially, I've heard that GV-20 was the device that was cloned by others (and now it seems we have clones of clones)
Originally posted by diniscampos View PostIn that case, my GV20 is what ? MK808 ? MK808B ? MK808B fake/clone ? I'm LOST....
Your pictures are definitively different from my MK808.
There are currently 2041 users online. 1 members and 2040 guests.
