Unbrick or fix NAND on the MK808
I went all the way to the end of this thread hoping someone had unlocked the secret but to no avail. I've got a MK908II that won't go into recovery mode. I was able to do the pin 8/9 thing and it comes up in MaskRom mode. I've tried every port on the PC and 3 different cables. I'm still unable to erase the NAND and get the same error everyone else does.
*sigh*
Just wanted to post my results as well.
I have little different nand chip then it is deccribed so i'm wondering what pin's should I connect?
Details:
MK808B
TEAN E120339
Rockchip RK3066
MT5931SA
MT6622
BTGCB5 18
Toshiba TC58TEG6xxxx - NAND
My device is also bricked because I didn't check before what exactly hw do I have under the hood
Please help
Kankarata
Thank you, this worked.
Finless (Bob),
Briefly shorting pins 8 (RE#: Read enable) and 9 (CE#: Chip Enable) on my SPECTEK PFB15 8GB NAND chip while connecting the OTG port allowed MaskROM Mode so I was able to clear the IDB and flash a working firmware. Phew!
Thanks again.
p.s. I used this Micron NAND Specification document for reference, since I couldn't find one for SPECTEK.
My MK908II - boot loop / recovery
Hello everyone
First I want to thank all of you for maintaining this site as one of the best when it comes to android smart devices.
My problem is as follows.
I have MK908/2 Rockchip3188
I wanted to update the kernel from 720p to 1080p. Something went wrong and now I can not flash any of firmvire because it is stuck in a bootloop. Every time I flash the firmware it says success, everything went well.
Then I connect my MK908/2 on my TV and stuck in bootloop recovery says something about device not found format data format cache rebooting.
Please help.
Please help.
Unbricked android - but doesnt boot properly
What an awesome site! While trying to upgrade my MK808B with the Finless ROM it bricked. Not sure why, mainly because I'm not very technically savvy. But that said, I used the method described in this thread and got it reset and was able to flash the rom, however, on reboot all I get is two penguins on the screen for a couple of minutes. Any suggestions on where to go next would be very appreciated. Thank you!!!
Originally posted by RK the Builder View PostWhat an awesome site! While trying to upgrade my MK808B with the Finless ROM it bricked. Not sure why, mainly because I'm not very technically savvy. But that said, I used the method described in this thread and got it reset and was able to flash the rom, however, on reboot all I get is two penguins on the screen for a couple of minutes. Any suggestions on where to go next would be very appreciated. Thank you!!!Prahjister ****MK808(nonB)****MK808B V5****MK808B Plus****UBOX R89**** CX919****MK808B Pro****Nexbox N9****Eny Em95****Matricon Q2****Tanix TX5 Pro****
Need help No drivers installed
Hi everyone ! I don't have drivers loaded on my PC so I can't connect my MK808b to it. As far as I understand to install drivers one need to connect the device in flash mode first, but mine is bricked... Is there any other way to install the driver on PC without using flash mode ? Thanks forward for any reply. )
I got MK808b bricked while trying to flash it with one of ROMs when the electricity in my house went down so I must be the lucky dog ) When trying to connect it to my PC nothing happens, even the blue light does not turn on. I have tried to get it into mask mode some time before but either I did something wrong or NAND is dead. Now I have a new PC and wanna give it a last try before I buy a new device.
NEW MK808B REALTEK HTC-T011-V4
Bricked flasing rom, have green status light in batchtools it goes into recovery without need to push reset buttonwhen plugged into otg, every rom faills to flash , I need to get it into MASK ROM mode to flash Nand chip, model Skhynix unsure if I short PIN 8 and 9 or shortpin 9 and 10 unable too find any info on this board. I have another stick same model only images work are T011 images. Unabe to obtain original stock image from seller. Anyone with stock image or any images for this model? also any help in putting this device into mask mode or flashing SD METHOD.
Anyone have this image MK808B T011_public_8723_20140911_V4.4.img
Originally posted by Akure View PostBricked flasing rom, have green status light in batchtools it goes into recovery without need to push reset buttonwhen plugged into otg, every rom faills to flash , I need to get it into MASK ROM mode to flash Nand chip, model Skhynix unsure if I short PIN 8 and 9 or shortpin 9 and 10 unable too find any info on this board. I have another stick same model only images work are T011 images. Unabe to obtain original stock image from seller. Anyone with stock image or any images for this model? also any help in putting this device into mask mode or flashing SD METHOD.
There are currently 2111 users online. 0 members and 2111 guests.
