Unbrick or fix NAND on the MK808
Re: NEW - Unbrick or fix NAND on the MK808
Originally posted by ShaWn View PostREMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by ShaWn View PostHere you are MK802 IIIS underhood. It has little bit different NAND chip than MK808, but fortunately same manufacturer and seriesGood luck for all unbrickers!
any help to my 808B ?
Originally posted by zaqx View PostHello,
I had succesfully installed a few images before..
Today while i try to flash sw , I have bricked my MK808B..
[ATTACH]1904[/ATTACH]
I have tried 8+9 MAskROm method... No Luck...
I have attached my log files...
Could you please help me?
well, I will join the club of the bricked mk808
Tried everything on this thread but still no go.
the difference is I think I fried my NAND by mistake, I did a cooling mod, and it worked perfectly, the unit has never run as cool as it did, but I think I either did one or 2 things wrong:
1.- put to much pressure on the heat sink I installed and by mistake I damaged the NAND as I see the factory heat sink does not touch the NAND and I think by the pressure I made it touch, and it probably screwed something
2.- I forgot to put the governor back to interactive after a benchmark, so it ran at 1.46 all night
next morning after watching movies/videos and doing some web browsing the keyboard was partially non respondent so I decides to reboot the unit, and that was the end of it.
I tried to erase the NAND it did it with no problems, tried to write the ROM, did it successfully but when it starts to check the download data it always fails.
so I went into mask mode by shorting pins 8&9, same exact result.
something to note is that the check always seems to fail at different parts (sometimes at 50k, others at 100k, and others even at 1000k it seems random)
sometimes I get "Download IDB Fail" on a first attempt, but if I try some more, it goes into writing the rom
so I am guessing my nand is FUBAR, I've tried 4 different cables, on 2 different Pc's on every USB port available, same exact problem.
I am attaching my log, but I don't think it will do any difference, but if anyone can check it and at least confirm this is dead, I can start ordering a new one as I am now in LOVE with this android stick :P
Log2013-04-02.txt
well, what do you know I managed to get my mk808 flashed again...
after trying about 100 times one of those times it worked..., but I did something different I took away the heat sink, then put the mk808 in mask mode, and since I had to go eat, I just left it there... I came back about 20 minutes later, then hit flash, and it worked, no errors, my MK808 is working right now, but I am afraid to re-flash it again to test it
anyways you guys might want to try that, I have no idea if it was just luck or did something happened in those 20 minutes in mask mode
EDIT: as I suspected, device died again after rebootLast edited by niabi; 03 April 2013, 03:48.
MK808 fix worked!!!
Thanks for you all for giving this information...
First I failed to flash 4.2.2 rom and got NAND erasing error... my MK808 was bicked.
I tryed everything (pin 8/9 method) with no success but after some testing I figure out that problem that caused my MK808 to brick was the USB cable.
So with a new USB cable (mine have some ferrite stablizer) all worked ok and my MK808 lives again
The cable that worked for me is like this one: http://www.mobilitysite.com/wp-conte...-cable-end.jpg
António
Portugal
cracked a solder joint I bet as the stick is dead I have a little proposition for you , why not have a go at baking it in the oven (crazy? maybe) I fixed an old graphics card that way when I over tightend a new cooler and screwed the card up it worked could not believe my eyes when the pc booted up, as long as you follow the google instructions you can find all over the web first google http://voices.yahoo.com/how-reflow-l...n-6784790.html .
MK809 T002
[ATTACH]1941[/ATTACH]
I have re-tried numoerous times, and notice that for me, it always fails at the same point around 180k.
Left it overnight, still no joy
Logs:
Originally posted by diniscampos View PostDon't forget to wait about 10 minutes between flash and test results.
This is very important because after flash the system still applying the firmware.
I flash roms many times a day as you may know.
This started happening to me recently. I thought my nand chip went bad but in fact I wore out the cheap connector pins on my USB cable. Got a new nice cable and no longer got the verification errors.
Also just to add, noise from your tv can cause failures like this so try to keep the cable away from your tv and for sure do not try to power the stick from your tv.
finally just because the verify failed does not mean the flash was bad. unplug it and pllug it in and it may boot fine anyway. Although I know it is not a good feeling to have a failed verify.
Hi today I have bricked my MK808B (RK 903 CHIP), i try flashed with a new software but i get error .
Today i plug my stick into a tv and the blue led doesn`t light , on TV screen nothing to see , even android ,so i connect to my PC and start flash but it doesn`t finishI get error and after this i can`t go in flash mode . My MK is not recognize by PC , nothing happend if i connect to USB. Earlier if i connect i see the connected device but now nothing . USB i check , cable to , other devices on this USB port work perfectly. Please someone give me a advice , what can i do ?
Bob can you look at my log please ?
ps.sorry for my languaageAttached FilesLast edited by kriss_261; 08 April 2013, 21:24.
Originally posted by Finless View PostI flash roms many times a day as you may know.
I think its dead.
Originally posted by kriss_261 View PostHi today I have bricked my MK808B (RK 903 CHIP), i try flashed with a new software but i get error .
Mine does, but due to non verification, perhaps it misses a last stage to close off the procedure, so again disappointment. I just hope you have more luck than I did.
Are you sure your unit is MK808B ?
Wich firmware did you use ?
There are currently 1534 users online. 1 members and 1533 guests.
