MK808 Android mini TV Player - Finless 1.5A Custom ROM
bt downloads to usb?
Some one try to download with a bittorrent downloader to a USB stick ? When I whant to download it sasy file to big fore USB ? Why the stick has. 16gig. And the movie 4 gig. Someone who has a solution?
An other question. My rc11 air mouse disconnect all the time. I must restart the android device to make it work again. Than when I,m I a app its disconnect again.Last edited by roerbakeitje; 29 December 2012, 16:00.
Truly Amazed!
Bob Finless 1.5a is truly amazing if you can stay close enough to the router or I figure out what's wrong with the top antenna, which could enable me to actually use it in the room I intended to use it in.
All the talk about Netflix being horrible I found incorrect. Mine is running fine close to the router where I'm getting about 7mb download speed. That should be closer to 15-20 but I really think the problem is with that front antenna (the wired one) on Mk808b.
All the hard work is becoming worth it. I even got my Bionic running Netflix and Showtime via HDMI as well as all my phone apps. I love connectivity!
@ Corba : Read (and in future post there ...) this : http://www.freaktab.com/showthread.p...D-on-the-MK808
Read carefully : "6) If you are shorting the pins, the PC should bong and the flash tool should say at the bottom "Found RKAndroid MaskRom Rock USB". If not, then your not shorting the pins properly OR you never had the drivers loaded to begin with. "
Press the hidden push-button while connect the stick to PC ...
For more info : http://www.armtvtech.com/armtvtechfo....php?f=4&t=973
Google Earth
Sorry if I've posted this in the wrong Thread, my question is about Google Earth running on the MK808 with Finless 1.5a.
Is there a trick to zooming out, zooming in is no problem. Can't locate a +/- feature or find a key sequence. No issue with Google Maps though.
Thanks in advance
Almost there....
I finally got 1.5 to flash, worked well, I watched a few youtubes,,, but when I rebooted, got no blue light.
And the RESETing no longer causes MK808 to be recognised, (it did for a while, but got errors in MIDDLE of doing NAND Erase , and errors in MIDDLE again on reload, but now seems dead), tried different USB cables...
If this is dead, wondering if pin 8/9 reset it the only option?, did I already void warranty?
Unplug the USB cord from OTG.
Hold down the reset button
while holding down the reset plug in the cable to the OTG port.
It should boot into flash mode and windows should BONG.
I have ONLY ONCE needed to do the shorting of the pins and that was due to flashing a bad loader from a tablet ROM.
Also make sure you are on the reset button inside! You should be able to feel it click when you stick a paper clip in the hole. It is actually hard to get on the button sometimes.
Tried multiple USB cables, multiple USB ports (on windows pc),,, seems dead.
Thanks for trying Bob
The MK808 is like a tank! It is hard to kill it.
I guess try the pin short but I am suprised it would die from hardware failure and for sure a non-overclocked ROM cannot kill it.
Originally posted by Finless View PostThe MK808 is like a tank! It is hard to kill it.
Three friends were waitign for me to give them a success report, looks like it's not in the cards!
Thanks again for you help Bob.
Originally posted by corba View PostI shorted pins 8/9, ROM and powered, Tool changed from "No Found RKAndroid....." to FOUND, but when I pressed NAND Erase (IDB), it timed out, tried 3x, same results.
Make sure your not going through a HUB and in BIOS make sure legacy USB is on and USB high speed mode is off.
Best I can say. Again these are HARD to brick permanently! Imagine what I do every day? I flash at least 30 times a day and like I said, MK808 is like a tank! PC has to be clean without a bunch of USB related installs.
Again last resort. Have you tried update.img and RKbatchtool 1.5? YOU MUST try this if you have not already.
There are currently 3904 users online. 0 members and 3904 guests.
