MK808 Android mini TV Player - Finless 1.5A Custom ROM
    Long mouse press on desktop. Menu will pop up to change wall paper.
    This is the most common way to do it on Android OS. Only SOME ROMs do they add it in display settings. It was never in display settings before ICS.
    Thanks Bob. this solved the issue of being able to change the wallpaper.
    Now another issue arises with the wallpaper though.
    If I set a static wallpaper, the right half of the screen stays black, but glitches and flickers(although the icons and widgets on that side remain still and are still functional).
    If I set a live wallpaper it fills the whole screen and works fine, but then slows down the performance of the device.
    So no matter the wallpaper I use, even the ones I download from wallpaper apps in the playstore, they glitch out.
    I've even tried using Apex launcher, and same thing happens with static wallpapers.
      did you try ZEDGE from Market?
      Theo
        Originally posted by PeterPan View Post
        Theo
        No, I used some HD wallpapers app.
        I also tried that wallpapers that come installed in the launcher already
        **UPDATE**
        I tried Zedge wallpapers and they were no better, still having same issue
          Teamviewer crashes with this ROM
          Teamviewer crashes with this ROM 1.5a installed.
          Anyone knows why?
            Odp: NEW - MK808 Android mini TV Player - Finless 1.5A Custom ROM
            This plattform is not supported by Teamviewer
            Wysyłane z mojego GT-I9300 za pomocą Tapatalk 2
              OIC, thanks!
                Does anyone have the keyboard layout file for the original MK808?
                After flashing finless 1.5a, I now cant use my right click as 'back' on my RC11 airmouse. I really liked that function and want it back.
                  My RC12 works fine and right click is back button... Just I had to put the dongle away from the device to avoid interferences with wifi. Perhaps you could just reflash your device?
                    Functions enquiries
                    Hi guys,
                    I'm planning to get one of this powerful tool. Just to ask whether tis ROM supports just any ordinary USB sound card I grab from any electronics store, heard tht tis ROM doesn't support or does any ordinary Windows OS computer USB wire/wireless keyboards works too?
                    Also since touchscreen is not possible, can I use the keyboard keys like W,S,A,D or Up, Down, Left, Right to control and play games like GTA3 or Gangsta, Asphalt, Dead Space, COD, CoM: Zombies etc? Will the player in the screen move or can I like press Ctrl, Shift or left click for firing? LOL, I know tht's a little ridiculous but can anyone jus share some experience abt controls during gaming cos I REALLY NEED tis info to play games!!!
                    Thanks for sharing & ur efforts!
                      Originally posted by haynz View Post
                      U only can use Fullscreen at new Youtube if u "share" it to VPlayer this times - but i hope they fix it soon. I dunno what sh.. they released there .. i even have to turn my 7" Tablet arround (90°) at a "Tablet optimized version"^^ - but it starts in Fullscreen there - only if u exit fullscreen mode it turns 90° - dunno why it doesnt start in Fullscreen at our MK808 - sry.
                      AND DUNNO WHY THEY REMOVED THE FULLSCREEN BUTTON !!!
                      On my Mobile/Tablet its auto-fullscreen by turning 90° - maybe they call this "cool"^^
                      maybe they want to give us something to think about - i don't find a explanation..
                      You're rite. The Youtube app indeed changed to a new interface which Gyro is a must to switch it to full screen nowadays. Although, I found this as quite pointless. And I think this applies to all devices including tablets n smartphones or watever devices that's Android running. Tht's wat I observe! Uninstall the damned update...
                        Anyway to get the download to work? 3 browers and 2 computers and 2 networks and I am still getting the log in alert. Even when I downloaded a browser fresh that I have never used before. Argh.
                          Did you click the "always keep me logged in" box?
                            I sure did think I had as I normally do. But I didn't have it on right now. And the download works now. I appreciate answering the question!
                              I have an RC11 though and the right click is not working as a back button.
                              Not sure how reflashing would fix this? I am already on 1.5a. If i reflash to 1.5a again then i'd still have the same mapping for the airmouse. I need the original MK808 mappings not the mapping that came with 1.5a.
                                Well reflashing did make it handle a bit better but mine still freezes up and needs to be unplugged about 1 time every 4 minutes. Guess I got a bad one.
