[EXPERIMENTAL] Unofficial CM12 for WeTek Play with Kodi & TVH Live TV
    Regarding the random black screen on channel change can anyone try this advancedsettings.xml (location on Android is "/sdcard/Android/data/org.xbmc.kodi/files/.kodi/userdata/") and tell me if it acts better? I didn't have any black channel since using it (3 days) but I don't wanna that it's just a lucky coincidence
    Code:
    <advancedsettings>
      <network>
        <buffermode>1</buffermode>
        <cachemembuffersize>52428800</cachemembuffersize>
        <readbufferfactor>10</readbufferfactor>
      </network>
      <pvr>
        <minvideocachelevel>10</minvideocachelevel>
        <minaudiocachelevel>15</minaudiocachelevel>
      </pvr>
    </advancedsettings>
    Regarding the XMLTV EPG I set up xmltv to use tv_grab_it for some channels (47 to be precise, and it takes ~1 hour per fetched day with the --slow parameter that includes descriptions) and fix it using tv_sort on the generated output because some channels don't have a stop time and this won't let tvheadend add them to its database.
    I used a Debian chroot in my Synology NAS and set up a crontab job in Synology's crond to execute a script, located at '/root/xmltv.cron' with this content:
    Code:
    #!/bin/sh
    # Package
    PACKAGE="debian-chroot"
    DNAME="Debian Chroot"
    # Others
    INSTALL_DIR="/usr/local/${PACKAGE}"
    PATH="${INSTALL_DIR}/bin:/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin:/usr/syno/sbin:/usr/syno/bin"
    CHROOTTARGET=`realpath ${INSTALL_DIR}/var/chroottarget`
    chroot ${CHROOTTARGET}/ su -c 'tv_grab_it --output /volume1/homes/alan/www/tvguide_wip.xml --days 3 --quiet --slow --cache-slow && tv_sort --output /volume1/homes/alan/www/tvguide.xml /volume1/homes/alan/www/tvguide_wip.xml' alan
    After that I enabled "Web Station" for the users and I can access my EPG from "http://NAS_IP/~alan/tvguide.xml" and use this URL as w*g*e*t parameter for tv_grab_file
    This is the result:
    If you install on your Play the Debian chroot that I posted yesterday you can practically do the same, just install xmltv on it running
    Code:
    sudo aptitude install xmltv
    (or, if you know what you're doing, compile it from sources installing the required dependencies, some perl modules)
    Install a cron daemon like "vixie-cron" and add it to "/system/xbin/debian-chroot" in the "start_services" function (like the template that runs the SSH server).
    Set it up, save the XML output somewhere like "/home/wetek/tvguide.xml" and replace the "w*g*e*t" line in tv_grab_file with "cat /storage/debian/debian-chroot/home/wetek/tvguide.xml"
    WeTek Play
    Recoveries: CWM | TWRP
    Lollipop ROMs: CyanogenMOD 12 | OMNI | Android TV
    KitKat ROMs: CyanogenMOD 11 | OMNI | ParanoidAndroid | AOKP
    Misc: Unbrick WeTek Play
      * ROM (CM12) 2015-02-07
      * ROM (Android TV) 2015-02-07
      Both Lollipop roms have been updated to match features/fixes of latest CM11 builds, plus upstream sources have been updated
      WeTek Play
        I installed the cm11 version, and kodi is no where to be found. Obviously i can download and install it, just wondering about the title listing it as having it???
          Originally posted by ChristianTroy View Post
          Just to be sure to have a good media experience use Kodi, I ran all my tests running the "14.1 RC beta" dated 12 Jan, that you can find here (this is a flashable zip and, in case you don't wanna sideload the apk you can just flash it and at boot it should be automatically installed), anyway feel free to experiment with nightlies, etc.
          Well... straight from the OP (release notes are there for something, not just because I had no other things to do and wanna write a romance ). Since I've been running with very good results the official 14.1 I'm going to update that part linking a zip that flashes the latest stable build.
          For good reasons I don't include a 50MB apk in a development build (that has been updated more than 10 times in less then 10 days), but I offer it as flashable zip.
          WeTek Play
            ooops, im blindSorry. Thanks for the great rom!
              New builds:
              * ROM (CM12) 2015-02-14
              * ROM (Android TV) 2015-02-14
              * ROM (CM11) 2015-02-14
              WeTek Play
                thank you, you make the world more diverse
                «Сомалійська Наноелектроника та Космонавтика»
                1. VS-IP015 - Android Sat Receiver - g18ref_th2
                2. WeTek Play - Android Sat Receiver - g18ref
                  Thanks, I'm using the CM11 version in my kitchen since 2 weeks and am very satisfied of it (so satisfied that I moved my main x64 HTPC to Kodi + TVH instead of VDR + VDR-sxfe).
                  Using it with Aeon Nox and LiveTv Mod, it really fits my needs, specially considering I can connect to it over the network for example to put some radio stations while working at the pc
                  WeTek Play
                    tvh-3.9.2509_oscam-r10566_android-wetekplay.zip
                    New Tvheadend built from sources (updated this morning), no more using OE's libraries but with another approach instead. I've built it with some enhancements in CFLAGS for the cortex-a9 cpu.
                    OSCam included, if you set it up the way I explained yesterday you're good to go, otherwise just configure it that way
                    ps: it looks like this version recognizes the hybrid c/t tuner as c only so if you need dvb-t keep using the one you're already using
                    WeTek Play
                      * ROM (CM12) 2015-02-22
                      * ROM (Android TV) 2015-02-22
                      * ROM (CM11) 2015-02-22
                      WeTek Play
                        tvh-3.9.2515_oscam-r10607_android-wetekplay.zip
                        Test zip that will change the following things:
                        - update tvh to latest sources (synced this morning)
                        - update oscam to r10607
                        - update wetekdvb.ko with the one from OE 5.0.4
                        PS: now the hybrid tuner is recognized, I had to change a couple of things
                        WeTek Play
                          ura!
                          left to finish when watching 1080p content from the satellite to Android and consoles with Amlogiс MX once and over again the leader.
                            your compiled of tvheadend works minix x8-h plus (s812). (dvb api 5.10) thansk ChristianTroy your efford
                              * ROM (CM12) 2015-03-05
                              * ROM (Android TV) 2015-03-05
                              * ROM (CM11) 2015-03-05
                              If you're upgrading from a build where you were running oscam, go to "mounts and storage -> format /system" before flashing the new stuff (or manually delete "/system/addon.d/80-oscam.sh" if you know what you're doing).
                              Changes:
                              * updated upstream code
                              * updated WeTek DVB kernel driver
                              * updated Tvheadend
                              * added OSCam (no support for it, it's a "grey area" thing)
                              * fixed a bug where the resolution was resetted to 720p @ 60hz under certain conditions (like when swapping HDMI input in some TVs), and use 1080p @ 50hz as fallback resolution
                              In case you wanna try a test zip with brand new OSCam and Tvheadend built with Android toolchain (NDK) flash THIS zip on top of today's build. I'd really like some reports about any crash using the native binaries.
                              WeTek Play
                                Hi ChristianTroy
                                First of all, BIG THX for supporting WetekPlay! Your involvement "pushed" me to buy it, and now I am really satisfied with it.
                                I have a few questions for you, and I would be very glad if you will find some time to send me your answers:
                                1. can you please explain me (from your point of view) - why should I use "your" Android version (with tvheadend) instead of pure Openelec version? Now those 2 variants look almost the same for me, the main difference if their base - Android or pure Linux, am I right?
                                2. I like your modification that once when system is "powered off" it is not really powered-off, it just "turns off the screen" and that way we can have "fast start-up". But, is there any chance to "power off" USB ports in that case, since I don't want that my external HDD is constantly on power? What do you think about that option?
                                3. In case that it is not possible to "power off only USB ports", can you have "parallel" version of your release - that will make "real power off"?
                                4. Is NTFS supported? Once I configured TV recording via native TV application, and it was not recorded at the end (my assumption was that the reason was that recording was too big (more than 2 hours) - that can cause problems in case of FAT system)...
                                5. and my final question: since I have DVB-C module and cable operator, is there any way to "decrypt" DVB-C channels? Currently I have PCMCI card/adapter that I put in my Samsung TV and it decrypt those channels, but is there any chance to decrypt them on WetekPlay too? If I understood correctly, OSCAM tool is used only for DVB-S, or I got it wrong?
                                THx
