1. it depends, if you wanna a faster system mainly based for tv watch only then OE is the better choice, but if you need apps from Android ecosystem then you have this further choice ,)
2/3. That's something I hadn't thought about. Disabling it would just require typing "echo DoNotSleep > /sys/power/wake_unlock" but tomorrow I'm going to try to build spindownd daemon using android ndk and will give you a link to try it, that will turn off disks after a user defined time idle.
4. Sure, NTFS, Linux EXT2/3/4 and ExFat are supported
5. You should see which encryption method uses your provider and search the net for an oscam configuration. After that you should get a usb smart reader like a smargo (the easiest to use and support because just uses libusb) or even possibly a smartmouse using a usb2serial adapter. In this last case I might have to build you the usb2serial driver for your device.
