Newest firmware for PMID703C is NOT rooted! Please help!
Hi, I've had 2 PMID703c tablets now. The newest one I bought this week 11/05/12 from Shopko and it had this version firmware on it: PMID70X.V01.86.00.20120817-OTA. It is NOT factory rooted! I went online and downloaded the latest firmware http://www.southerntelecom.com/polar..._4.0v3_OTA.zip and this TOO is not factory rooted! I had to downgrade the brand new tablet to a firmware version I downloaded from 5/2012 that -is- factory rooted. This would be fine except both tablets with the 5/2012 software on them have issues with randomly shutting down or not turning on, so I would like the newest firmware installed. How do I root this version? I cannot access root to copy/save/modify anything with a root-capable explorer, I get an error message saying its not rooted. I really need root access for google play, several apps I frequently use are not on Amazon appstore or slideme. Please help!Tags: None
Originally posted by ilukeintheband View PostHi, I've had 2 PMID703c tablets now. The newest one I bought this week 11/05/12 from Shopko and it had this version firmware on it: PMID70X.V01.86.00.20120817-OTA. It is NOT factory rooted! I went online and downloaded the latest firmware http://www.southerntelecom.com/polar..._4.0v3_OTA.zip and this TOO is not factory rooted! I had to downgrade the brand new tablet to a firmware version I downloaded from 5/2012 that -is- factory rooted. This would be fine except both tablets with the 5/2012 software on them have issues with randomly shutting down or not turning on, so I would like the newest firmware installed. How do I root this version? I cannot access root to copy/save/modify anything with a root-capable explorer, I get an error message saying its not rooted. I really need root access for google play, several apps I frequently use are not on Amazon appstore or slideme. Please help!
Originally posted by MdPhoenix View PostSame thing just happened to me on a PTAB7XC.[...] Anyone have a way around this?
I downloaded the LiveSuite images for both the 703C and the 7XC, pulled 'em apart in Windows, then examined them in Linux. They are identical. They are also very un-rooted: release build, not debuggable, and worst of all, no 'su' binary on them. However, getting them rooted may be very simple (maybe).
Before my own Polaroid became a permanent construction zone, I found that trying to enter Recovery using the hardware buttons didn't give me anything useful. However, selecting Settings->Backup & reset->Recovery Mode produced the standard Recovery menu. I just looked at a similar tablet (a D2Pad), and its menu offers "apply update from external storage". Are you able to get into Recovery as described, and do you have that menu entry? Also, do the buttons on your tablets let you choose an item, then select it? (On the D2Pad, the Volume buttons move the selection but the Power button doesn't act like an Enter key).
If everything works as it ought to, then it shouldn't be too hard for me to create an "update.zip" that installs 'su' and replaces 'build.prop' with one that's more root-friendly. If that fails, we can look into creating a rooted Live Suite image
Sadly, that option is not there. I wish I could simply find the last update which was on their website. That would solve the entire issue.
However if you're able to program SU into a Livesuite ROM, I'll try it. I've got 4 of them. Only one is unrooted now. It's worth a try. Besides, my wife shops at Kohl's regularly. Apparently they'll take back anything. She'd figure out a way to get them to accept the return if it bricks.
Originally posted by dolorespark View PostVery possibly... I downloaded the LiveSuite images for both the 703C and the 7XC, pulled 'em apart in Windows, then examined them in Linux. They are identical. They are also very un-rooted: release build, not debuggable, and worst of all, no 'su' binary on them. However, getting them rooted may be very simple (maybe). Before my own Polaroid became a permanent construction zone, I found that trying to enter Recovery using the hardware buttons didn't give me anything useful. However, selecting Settings->Backup & reset->Recovery Mode produced the standard Recovery menu. I just looked at a similar tablet (a D2Pad), and its menu offers "apply update from external storage". Are you able to get into Recovery as described, and do you have that menu entry? Also, do the buttons on your tablets let you choose an item, then select it? (On the D2Pad, the Volume buttons move the selection but the Power button doesn't act like an Enter key). If everything works as it ought to, then it shouldn't be too hard for me to create an "update.zip" that installs 'su' and replaces 'build.prop' with one that's more root-friendly. If that fails, we can look into creating a rooted Live Suite image
Originally posted by elektrik View Posti will download the i,age and see if I cank cook a rooted factory image if someone is willing to test it (I do not have a 703c)
Originally posted by MdPhoenix View PostDo we think the 703c image will work on a 7XC?
Now, before we go tossing 275mb boat-anchors around, let's try one more thing. ADB has a command to reboot into recovery but I'm at work so I can't check what it is. Could you open a command window, change to whatever directory has ADB, then enter just "adb". It will give you a long list of commands (you may have to scroll back). One of them should be something like "reboot-recovery". Give that a try to see if you can get to a usable recovery menu as described above. Solving this with a 1mb file would be nice.
Originally posted by dolorespark View PostI've already confirmed the LiveSuite images are identical.
Originally posted by MdPhoenix View PostI typed "adb reboot recovery" and it simply rebooted. Is there anything in the syntax I'm missing?
Also, don't we need to push a recovery.img file first?
I'm even newer to Android than you, but from what I gather, many/most ROMs have a standard recovery facility that forms the basis for 3rd-party enhancements like CWM. They may make it hard (or impossible) to get to but it's usually there.
Originally posted by dolorespark View PostI've got that done, all I have to do is put the pieces back together again. The reason I wanted to do an update.zip is that it would be 1mb vs 275mb - plus I could test it.
Originally posted by dolorespark View Postget ready for a boat-anchor...
There are currently 1933 users online. 2 members and 1931 guests.
